Remote Brake Reservoir
Cillit-BANG
PostPosted: 18:04 - 30 Sep 2006    Post subject: Remote Brake Reservoir Reply with quote
Can someone point me in the right direction of a good place to pick up a generic remote reservoir please. Google and Ebay aren't really turning anything up.
It's for an NC30, but any small pot with a mounting bracket/hole will do as i'll be looking at making a new bracket anyway so it's doesn't really have to be of the exact same specification.
Also, with regards the connecting pipe, can it be normal clear tubing that you can buy at B&Q or does it have to be specific for brake fluid. It's for my track bike so fluid changes will be done on a frequent basis so I'm not too worries if it accelerates fluid fade.
Cheers, Cillit.
PostPosted: 19:33 - 30 Sep 2006    Post subject: Reply with quote
Here goes:-
https://www.moto-racing.co.uk/cat--Motorcycle-Brake-Accessories--All+Brake+Accessories.html
As to the pipe they sell it as well. While it is under no pressure you could probably get away with normal hose, normal clear hose will harden and go cloudy quite rapidly (and will also probably kink rather too easily).
Kram
PostPosted: 19:37 - 30 Sep 2006    Post subject: Reply with quote
Do the type of master cylinder matter? (I.e. if it came off a twin disc, or single disc brake system) etc...
and brake line connectors, kind off universal size?
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
PostPosted: 19:39 - 30 Sep 2006    Post subject: Reply with quote
For the reservior it doesn't matter too much (plenty of racers just use a length of clear pipe for the rear brake reservior).
Does make a difference for the master cylinder.
Cillit-BANG
PostPosted: 13:11 - 01 Oct 2006    Post subject: Reply with quote
Nice one, cheers Keith Thumbs Up
Kram
PostPosted: 14:03 - 02 Oct 2006    Post subject: Reply with quote
So, would I be able to fit a mastercylinder from an NC30, onto my NC21??? as they sre both still vfr400's? and are both twin disc?
feef
Energiser Bunny
PostPosted: 14:32 - 02 Oct 2006    Post subject: Reply with quote
also depends on the bore and stroke of the caliper pistons..
if both bikes have the same calipers, then you shoud be okay.
depends how much fluid the caliper requires to move the piston(s) the correct distance
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
Cillit-BANG
PostPosted: 18:15 - 02 Oct 2006    Post subject: Reply with quote
The actual fluid required is quite small though isn't it, just the size of the master cylinder? Not all of that either as the lever only moves the cylinder a portion of it's total travel.
I thought the recervoir was for general expansion and to ensure there is always a supply of fluid to the master cylinder. It doesn't actually use all the fluid in the pot because the levels certainly don't empty when you pull the lever.
feef
Energiser Bunny
PostPosted: 18:21 - 02 Oct 2006    Post subject: Reply with quote
My post was in response to the question about fitting a non-standard master cylinder. You're right about the reservoir being just a fluid supply.
a
PostPosted: 20:31 - 02 Oct 2006    Post subject: Reply with quote
Rough idea of how much fluid will be used. On the ZZR600 the pistons are ~30mm diameter, with 8 pistons. Say 5mm of pad from new to knackered. That is about 28cc of fluid.
The last post was made 20 years ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 67.58 Kb
