Fuel Injected bikes
Misc
PostPosted: 19:49 - 02 Oct 2006    Post subject: Fuel Injected bikes Reply with quote
Hello, i have a quick question.
Just reading about & read you can get fuel injector cleaner, what exactly does this do & where may i find it?
Also, heard i should be using Super unleaded, i've been using normal.
Thank you. Thumbs Up
Zimbo
PostPosted: 19:56 - 02 Oct 2006    Post subject: Reply with quote
I suspect the injector cleaner you hear about is the fuel additive, found in Halfords or any car accessory shop.
As for which fuel to use, this depends entirely on the bike. A few of the modern super sporty ones will be better on higher octane fuel, most will be fine on normal underleaded.
Misc
PostPosted: 20:02 - 02 Oct 2006    Post subject: Reply with quote
So any injector for petrol is fine with bikes & cars? is there a 'best' one? Also, is there a specific time to use it, or only if it's running a bit weird?
Thanks for clearing that up for me.
0ddball
PostPosted: 20:33 - 02 Oct 2006    Post subject: Reply with quote
Doesn't do much in most cases but the best one is said to be stp fuel system cleaner (in a silver bottle) which can help if the injectors aren't too bad.
Other than that it's a case of whipping them out and finding someone with an ultrasonic bath or even better and ASNU machine which can clean and check the flow rate and pattern.
Misc
PostPosted: 21:05 - 02 Oct 2006    Post subject: Reply with quote
Will look out for it.
Finglonga
PostPosted: 21:46 - 02 Oct 2006    Post subject: Reply with quote
How olds the bike and how many miles has it done?
Andy Sez....
F.Y.Y.F.F.
Misc
PostPosted: 21:53 - 02 Oct 2006    Post subject: Reply with quote
it's a 2003, & about 10k miles.
Finglonga
PostPosted: 22:17 - 02 Oct 2006    Post subject: Reply with quote
Shouldn't need it realy yet then. Did mine at 40k and it made no difference at all, I only did it as a spring clean type thing...Never spending money on that stuff again untill I have problems running.
Worth remembering all modern fuels have shit loads of detergent in them anyway to keep the engine cleaner. Wink
Andy Sez....
F.Y.Y.F.F.
sickpup
Old Timer
PostPosted: 22:23 - 02 Oct 2006    Post subject: Reply with quote
If you go to Mottingham Motorcycles on Court road Mottingham, ask Gary for the fuel system cleaner that Charlie at Racer sells.
It isn't cheap but is the best stuff I've ever used. Don't get it on your paintwork as it will melt it.
Misc
PostPosted: 14:13 - 03 Oct 2006    Post subject: Reply with quote
I just bought it (Stp silver) & need to know how much to put in, the instructions say put it all in with a full tank but i'm guessing they mean for cars, is it the same for bikes?
Thanks.
mrbluesbox
PostPosted: 17:41 - 03 Oct 2006    Post subject: Reply with quote
Does anyone know if id get better acceleration / mileage on a 2 stroke (Derbi GPR 125) using super unleaded ?
Thanks
Gaz.
krebsy
PostPosted: 18:32 - 03 Oct 2006    Post subject: Reply with quote
I just chuck in about a 6th of a bottle (at most) of RedEx to a full tank every few months to flush the fuel system clean.
K.
1280 x 1024.
THCi
PostPosted: 23:10 - 03 Oct 2006    Post subject: Reply with quote
Thanks
Gaz.
No.
Past: GZ 125 K4 Marauder, VL 125 LC Intruder, FZS 600 Fazer. Present: GSF 600 N K3 Bandit, GSX-R 600 X(soon)
"We're not gonna die. We can't die, Bendis. You know why? Because we are so...very...pretty. We are just too pretty for God to let us die."
PostPosted: 23:15 - 03 Oct 2006    Post subject: Reply with quote
It gives you no more power. Just allows you to run a higher state of tune to produce more power, but if you had tuned the engine to take advantage of it then using normal fuel would result in a good chance of engine damage.
The last post was made 19 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 79.23 Kb
