Where does the choke cable go?
5v3d3b0
PostPosted: 16:58 - 03 Oct 2006    Post subject: Where does the choke cable go? Reply with quote
I've done the whole carburetor but I cant figure out how to put the choke cable on. Theres another unscrewable thing just like the cap for the acceleration cable, but I cant fit the choke cable all the way through...Help
NSR Mick
PostPosted: 17:04 - 03 Oct 2006    Post subject: Reply with quote
What bike? Rolling Eyes
5v3d3b0
PostPosted: 17:22 - 03 Oct 2006    Post subject: Reply with quote
Yamaha TZR 50 2005
Paddy Blake
PostPosted: 00:59 - 04 Oct 2006    Post subject: Reply with quote
Can you show a photo of the end cable and or the carb.Cheers.
Paddy.
5v3d3b0
PostPosted: 22:57 - 04 Oct 2006    Post subject: Reply with quote
Here are pics of the carb. Forgot to get any of the cable...The cable is just a wire with a blob at the end about twice the diameter of the cable. Looks exactly like my acceleration cable.
Paddy Blake
PostPosted: 23:02 - 04 Oct 2006    Post subject: Reply with quote
Is there a spring on the end of the cable.Sometimes there is a spring and
a plunger on the end of the cable.To remove the plunger whitch is to big
you must pull back the spring and move the plunger sideways to take
it of and then put the cable trough the adjuster and then put the spring
and plunger back on and put the rest to gether.
Paddy.
5v3d3b0
PostPosted: 20:03 - 05 Oct 2006    Post subject: Reply with quote
No there is just the cable covered in plastic, and uncovered about 10cm. Then there is a rubber bit about 5cm on top of it which I can move around...
Welshd1k
PostPosted: 21:08 - 05 Oct 2006    Post subject: Reply with quote
i think you are missing a little part Sad
see the last but 1 pic on my nsr whr choke goes on by the air inlet on your bottom left hand corner. the cable goes in there and is spring loaded. if that is a top down view
cheekythomas
PostPosted: 10:38 - 06 Oct 2006    Post subject: Reply with quote
On picture 0038 the choke cable goes into the smaller silver opening at the bottom RH side.... there should be a small plunger the cable clips too that locates in that hole, and a plastic cover goes over it and uses the screw hole next to it too hold it down.
See the FOR SALE section if you fancy a 21mm carb conversion Laughing
The last post was made 20 years, 1 day ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 58.58 Kb
