fork seals?
Welshd1k
PostPosted: 17:26 - 03 Oct 2006    Post subject: fork seals? Reply with quote
ok i need mot on the bike tomorrow (ns125r-k) and i have one leaky for seal!!! i can get new ones for £5 but how the ferk do i fit them? i was told just to drain oil out of the fork and take it liek that then refil when home is this safe????
T1z3R
PostPosted: 17:29 - 03 Oct 2006    Post subject: Reply with quote
bodge it.
lift the dust seal and put a ring of cotton wool around the stanchion then replace the dust seal.
lets you pass the MOT and fix the seal when you have more time Thumbs Up
duck my sick!
Welshd1k
PostPosted: 17:43 - 03 Oct 2006    Post subject: Reply with quote
well i have been riding it like it is for over a month so cototn woll you say Very Happy
thanks
T1z3R
PostPosted: 17:50 - 03 Oct 2006    Post subject: Reply with quote
well...if youve been riding it like that for that long then i hope theres still enough oil in there Shocked
duck my sick!
Welshd1k
PostPosted: 17:53 - 03 Oct 2006    Post subject: Reply with quote
yea i only use it on weekends and i toped it up a few times juat aint got around to dong it to be honest and its been of the road after my crash and now needs a mot
Marci
PostPosted: 18:12 - 03 Oct 2006    Post subject: Reply with quote
Slacken nuts in top of forks, don't remove `em.
Slide dust seal out of lower section and shove it up the fork. Masking tape in place so u don't lose `em.
Bit of rope over a beam in the garage or similar round each handlebar. Hoik it up a good 8" off the floor.
Remove front wheel and axle.
Pop bucket under bottom of each fork. Open drain screw that should be on front face of each fork about 2" up from bottom. Let oil drain out. Pump lower section up n' down to encourage it.
Stick allen key up hole in bottom of fork, undo small bolt. Let rest of oil drain out.
Fully open tops, be prepared - they're sprung. Remove spacer and spring, making sure to note which way up spring was. It's only meant to go in one way round.
Pull bottom off fork.
Prise out old seal.
Pop in new seal (use a big socket to hammer it home - big enough NOT to hit the inner lip of the seal). Make sure you stick it in right way round.
Lube inner face of seal.
Slide bottom back on. Push dust seal back down. Put bolt back in bottom. Seal up bleed screw on front. Put front wheel / axle back in.
Pour required amount of forkoil in top of each fork whilst still hanging with forks fully extended. Use a ruler to measure from top of fork - memory says should come to 7cm from top of fork - but check this against manual. Put tops back on. Drop back down.
Done.
Sounds more complicated than it is - essential part is having summat to lift it up off the ground. Other than that it's actually REALLY easy.
If memory serves correctly, Haynes manual for the NS125RK states to use Automatic Transmission Fluid (ie: Transmission fluid for an automatic car) in the forks...
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
Welshd1k
PostPosted: 18:16 - 03 Oct 2006    Post subject: Reply with quote
ill bodge it for tomorrow then do it properly friday so i can go to builthwells saturday Very Happy
thanks ill print it out and follow what it says
Paddy Blake
PostPosted: 19:23 - 03 Oct 2006    Post subject: Reply with quote
I would,nt go with out the oil.You could drain the forks and put engine oil
in instead.It is much thicker so put less in.
The last post was made 19 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 55.65 Kb
