Polishing a frame & swingarm
loply
PostPosted: 23:53 - 04 Oct 2006    Post subject: Polishing a frame & swingarm Reply with quote
Evening folks,
Well further to my thread about polishing rearsets & downpipes, my frame and swingarm are fairly tatty and the idea occured to me that I could polish them completely. There's chips of paint missing in places and slight rust spots in others. I have quite an extensive polishing collection all of a sudden, so I'm tempted to utilise it.
They're currently finished in a desaturated gold color, which chips off in places so I gather it's painted and then lacquered? Both the frame and swingarm are aluminium pieces.
Anyway my question is what are the options for refinishing them afterwards?
Can I polish them to a high polish and then simply lacquer them? If possible I'd like to do this - But I don't know if its a valid method.
Chroming would be too expensive and too tarty for my tastes and wallet.
Could I achieve a nice finish with an automotive sprayer and some automotive paint?
Is having the frame and swingarm anodised an option?
Thanks for any input.
Yamaha SZR660 Caution to the wind, the throttle pinned!
the grim reaper
PostPosted: 13:30 - 05 Oct 2006    Post subject: Reply with quote
Anodised, maybe. Polished, NONONONONONONONONONONONO, it looks horrible and is a complete pig to maintain, polished frames and swingarms are the equivalent of furry dice, IMO.
Grim
mrtEE
PostPosted: 14:14 - 05 Oct 2006    Post subject: Re: Polishing a frame & swingarm Reply with quote
Speeky no eenglish?
0ddball
PostPosted: 14:17 - 05 Oct 2006    Post subject: Reply with quote
Question
loply
PostPosted: 15:49 - 05 Oct 2006    Post subject: Re: Polishing a frame & swingarm Reply with quote
Speeky no eenglish?
Okay, corrosion then. Its brown underneath so it near enough looks like rust, though I guess the brownness is probably an undercoat or something.
loply
PostPosted: 17:52 - 05 Oct 2006    Post subject: Reply with quote
It's painted in a low-saturation gold color.
I'm sure it's painted on account of the fact that it's scraped off and chipped off in places, revealing a dark brown underlayer (the color of a well used 1p coin).
This may be primer of some sort, or just scum left over from the underside of the topcoat?
loply
PostPosted: 17:57 - 05 Oct 2006    Post subject: Reply with quote
Best picture I could find, doesnt give you a very good idea of finish type, but at least you can see the color:
https://img139.exs.cx/img139/4337/blauwyamahaszr6603eo.jpg
craigs23
Mr Muscle
PostPosted: 20:55 - 05 Oct 2006    Post subject: Reply with quote
If it is ally, it will polish.
There are a couple of methods involved to get a good finish. I prefer a more hands on approach using wet and dry.
WARNING! THIS IS VERY PERMENANT AND MAY COMPROMISE THE VALUE OF YOUR BIKE (some see polished frames and what not as disguising crash damage) I did and they are currently sitting unused in my garage - I didn't like the lack of control they didn't give. So I use wet'n'dry. The original finish depends entirely on what grade to start with. Original finish - 240 grit; quite a bit of hard work at this stage, but it gets easier (relatively) when moving up the grades. Remove all surrounding bodywork/obstructions, fill a bucket of water, apply a tiny amount of washing up liquid, tear a hand sized patch of wet'n'dry up and then sand away like you would paintwork. Keep the surface saturated.
For painted/laquered surfaces you may want to try Nitro Morsing first. I have little experience with this stuff, but heard it works pretty well (won't remove the finish of a frame though). Anyway, gradually move up the grit levels - the key is to be patient - it will take a while. Miss a spot and leave a deep(ish) scratch in your metal work and it will show in the levels thereafter, so be careful not to just hack away in the first stages. Once you've moved up the 240-500-800-1000-1200-1500 grit stages and most sratches have been polished away (along with the original finish) dry thoroughly and then apply some Autosol to a cloth. Use the same technique as described for metal polishing above.
My (previous) two-wheeled furry dice:
https://i3.photobucket.com/albums/y51/whers84/mirrorpolish.jpg
My Blade top yoke, this is the kinda finish obtainable with wet and dry:
https://i3.photobucket.com/albums/y51/whers84/DSC01710.jpg
Jack_Cheese
PostPosted: 22:57 - 05 Oct 2006    Post subject: Reply with quote
Use nitromors to get rid of the paint, wet and dry it as craig says. When i did mine, i then got an electric polishing mop and rubbing compound and used that. The 1500 grit and autosol didnt seem to work for me, so i used the rubbing compound and then the autosol and mine came up like a mirror. It's the first piece of metal i've ever polished and didn't come out too bad.
https://w1.bikepics.com/pics/2006/07/11/bikepics-631386-full.jpg
Not up to craig's standards, but for a first go and little effort it's not a bad result.
By the way, if/when you use nito mors, get a ventillator, and do not let it come into contact with anything you value, including yourself. It's the most effective paint stripper out there, but it'll eat most plastics and rubbers (including your tyres according to some...). It also needs disposing of very carefully.
BLUEX5 wrote:
anodising big complex castings will cost ££££££.
it's practically the same process as electroplating with a few differences, so i can't see how it'd be that expensive
BLUEX5 wrote:
Really you need to strip the bike and get the bits bead blasted to a smooth finish in lieu of polishing them up. I know a lot of people that havn't bothered laquering after polishing, and keep on top of it with autosol
You don't need to "keep on top of it" Just autosol it once a month, if that and the shine will come back with every application.
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
PostPosted: 23:07 - 05 Oct 2006    Post subject: Reply with quote
Personally I would not do it. Far too much work in the future to keep it shiney.
You could get it powder coated or anodised, but both would require stripping the bike entirely. I understand than Spondon Engineering can anodise frames. No idea of cost.
The last post was made 20 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 78.54 Kb
