GPZ Gearbox - on the way out?
mchaggis
PostPosted: 12:26 - 07 Oct 2006    Post subject: GPZ Gearbox - on the way out? Reply with quote
GPZ500, 1989, 27.5k miles, oil and filter in need of changing.
Something the other day finally confirmed the problem for me. Every time I throttle on (in any gear) there is a jerk as the power comes in. When I close the throttle from high rpm, every so often there is a funny jerk in the delivery.
The clincher was yesterday, throttling off in 3rd from a quick squirt up a short section of dual carriageway before it turns into a 40 with a speed camera. All of a sudden, I'm in second and the engine's revving it's nuts off as you might expect. It has happened to me before too, where I've just changed down a gear and the bike's changed down another, going from 5th to 3rd at 70. Confused
Basically, gearbox lash + dropping down gears when throttling off from high rpm = gearbox gubbed? But what and how? It never drops out of gears under high acceleration. I'm confused to say the least.
I must not be a troll...
Mmmm, Guinness
PostPosted: 12:46 - 07 Oct 2006    Post subject: Reply with quote
Under load the dogs (if undercut) will be less likely to let go. If not undercut then the load will help it pop out of gear. No idea on the GPZ box (but given it is a fairly pleasant gear change I suspect it isn't undercut). Normally would just dump you into a false neutral though on most bikes.
However I cannot see a likely way for the box to go down 2 gears at once.
mchaggis
PostPosted: 14:02 - 07 Oct 2006    Post subject: Reply with quote
As far as I know, it's only actually changed down 1 gear at once, but I'd only just changed down myself, hence the buttock clenching moments.
Mmmm, Guinness
PostPosted: 16:07 - 07 Oct 2006    Post subject: Reply with quote
Not sure how it could, although possibly very worn selector forks might allow it to happen (but I would expect these to have caused loads of problems before getting to that stage).
Paddy Blake
PostPosted: 16:47 - 07 Oct 2006    Post subject: Reply with quote
I think what you mean is it can go from 5th down to 4th then slip out of
4th into 3rd.
I would change the whole gearbox drum and all before it happens in the
wet and you end up on the ground.
Paddy.
davidimurray
PostPosted: 12:47 - 09 Oct 2006    Post subject: Reply with quote
May sound stupid - but have you checked the state of your chain and sprockets?
mchaggis
PostPosted: 13:44 - 09 Oct 2006    Post subject: Reply with quote
Funnily enough, since I tightened the chain and changed the oil and filter yesterday, it was a lot better this morning. It was purring like a pussycat with 3.4 litres of clean Castrol GTX.
Mmmm, Guinness
PostPosted: 22:05 - 09 Oct 2006    Post subject: Reply with quote
They can develop a LOT of play on the cush drive too. Give it a check (by trying to rotate it one way then the other). Shim it out with strips of inner tube if necessary (dinnae bother buying new rubbers, they have play in them from new).
The last post was made 20 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 58.33 Kb
