| blamchez |
 blamchez Scooby Slapper
| alains |
 alains World Chat Champion
 Posted: 17:27 - 07 Oct 2006 Post subject: |
did you open the fuel tap ?
now , put your battery on charge (if you do it on the bike disconnect the + ) . then try to start (choke on , no acceleration)
if it doesnot start , take off plug and :
- plug wet , ignition doesnot work . put the cap on the plug and let the plug lying on the cyl head , push starter button 5 sec. and look if sparks come , if not , change plug and try again . if still nothing download https://www.geneva-racing.com/~alains/NSRtips.doc and look chapter about ignition bug
- plug dry , verify the fuel line if ok , take off carb and check the fuel valve ____________________ the worst day fishing is better than the best day working |
| blamchez |
| Minty |
 Minty World Chat Champion
| alains |
 Posted: 20:06 - 07 Oct 2006 Post subject: |
i think he was clear the reed block is not a plate ____________________ the worst day fishing is better than the best day working |
| blamchez |
| Sephiroth |
 Sephiroth World Chat Champion
 Posted: 17:39 - 08 Oct 2006 Post subject: |
Bump start it.
Push it forward *getting a mate to help is alot easier on the legs * then kick it in gear and let go of clutch. |
| Minty |
| 0ddball |
 0ddball World Chat Champion
| alains |
 Posted: 19:14 - 08 Oct 2006 Post subject: |
electronics do not like that  ____________________ the worst day fishing is better than the best day working |
| Fawbish |
 Fawbish World Chat Champion
| 0ddball |
| ROB_NSR |
 ROB_NSR Nitrous Nuisance
| Finglonga |
 Finglonga World Chat Champion
| alains |
 Posted: 22:12 - 08 Oct 2006 Post subject: |
i think it's better you learn than saying stupidities  ____________________ the worst day fishing is better than the best day working |
| Jebus |
 Jebus Brolly Dolly
 Posted: 22:31 - 08 Oct 2006 Post subject: |
99% of the cars on the road are going to be 12v the only "car's" that will be 24v will be some ex miltary stuff and this is so they can jump start the trucks and even some of em have to have a plug so they can jump a helicopter! this is in the case on miltary land rovers anyway the only thing that you might want to watch out for is a car battery is a hell of a lot more powerfull than a bikes one, dont want a massive surge of power or anything like that. ____________________ 2nd time around CBT: 8/9/11
125 Varadero |
| blamchez |
| finpos |
 finpos World Chat Champion
 Posted: 10:47 - 09 Oct 2006 Post subject: |
heh - I reckon you ought to do your lass a favour and get her to change the battery in her bravo before it craps out on her. Car battery in good nick will turn a small bike over for a good long time; sound like hers isn't too clever any more
finpos. |
| novocaine100 |
 novocaine100 L Plate Warrior
| finpos |
| 0ddball |
| sickpup |
 sickpup Old Timer
| novocaine100 |
| finpos |
 Posted: 16:25 - 09 Oct 2006 Post subject: |
Ok, it's do this or finish another completely useless powerpoint presentation.
The resistance in the relay winding is a function of the wire used, so we can assume that is constant. Referring to ohms law, I=V/R, R is constant, V is constant (12V), so the amount of current flowing throught the relay coil is also constant, regardless of the amp/hr rating of the battery you choose to connect to it.
Now, it's true that the relay coil will produce heat and this will affect the resistance of that coil. However, I think we must rely on the fact that whoever designed said relay isn't a complete retard, and actually managed to build one that dissipated that heat in a satisfactory manner so not to cause a problem.
If this were not the case, then, again, the reserve capacity of the battery is not relevent. The heating problem would occur both with the low capacity battery and also the high capacity battery.
Now, it could be that you are talking about the current that is passing through the relay's switched circuit to the starter motor. In exactly the same way, ohms law once again suggests that there would be no difference in any ill effects with regard to the capacity of the battery, as long as the voltage is the same.
Moving on...
It's the job of the regulator to keep it's output VOLTAGE clamped very close to the nominal voltage of the battery. The internal resistance of the battery is tiny (and more or less constant), so again, with I=V/R, we will see that any small difference in the voltage output of the regulator from that of the battery will cause a large change in the amount of current that the battery draws from the regulator, which we prefer not to happen because we only want to trickle charge the battery, as opposed to boil the arse off it.
Finally...
You don't pump anything anywhere. The amount of current passing through a curcuit is defined by.... [answer left to reader]
finpos. |
| Minty |
 Posted: 17:12 - 09 Oct 2006 Post subject: |
 ____________________ My fingers smell of your mum. |
The last post was made 20 years, 23 days ago. Instead of replying here, would creating a new thread be more useful? |
