Fuel Injection
sunbear
PostPosted: 12:27 - 09 Oct 2006    Post subject: Fuel Injection Reply with quote
Might be a silly question, but i was just wondering what the benefits of fuel injection are ? A lot of bike reviews seem to slag it off for being "on, off" or "bad fuelling". Why move away from good old carbs ?
Cheers Thumbs Up
Bikes had : BMW F650, suzuki tr50, gt125, SV400, GSXR600 SRAD. Honda CBR900RRP, CBR600FX, CBR1000F, VT600, Transalp 600, mtx125, nsr125r, CB500T, Yamaha fy50, tzr125, tdr125, XV535, Diversion 600, Fazer 600, TDM850 MK1 & MK2, Majesty 400, XV 1100. Cagiva mito evolution, Aprilia rs125, Piaggio x9 125. DNA 125 . Suzuki Bandit 600, GZ125 Marauder, RF600 , RF900RS2, Kawasaki ZZR400, ZX6R Ninja, ZZR600 . Ducati 750 Sport . Triumph Tiger 955i. CURRENT : 2004 Kawasaki Z750 and LOVIN IT !
finpos
PostPosted: 12:36 - 09 Oct 2006    Post subject: Reply with quote
Put simply, using fuel injection gives you much better control of the fuel/air ratio at any given condition. that means manufacturers can increase fuel efficiency and reduce emmissions, which is what they need to do to meet modern standards.
I think one of the best examples is what happens when you are on overrun, i.e. engine braking. Carbs always bleed a small amount of fuel through, which is usually wasted - popping an burbling. With modern fuel injection, you simply cut the fuel entirely. instant fuel and emmission saving, but might explain the on/off thing.
What they are complaining about is not that injection is worse than carbs, but the fuelling and ignition mapping they use is biased towards efficiency rather than fun. It's not "bad", it's "different" Smile
(Remembers horrific month trying to get mechanical fuel injection system working before throwing it in the bin and fitting carbs)
finpos.
0ddball
PostPosted: 13:06 - 09 Oct 2006    Post subject: Reply with quote
I don't see why they seem to get it so bad on a bike. Apart from a few ropey years in the 80's car's have been running it fine for 20 years.
Injection, mapped properly, is better than carbs in every way, i can only assume bike manufacturers purposely map them in the way they do for good reason.
Plus i think half of the complaining is for the sake of it from older bikers who just don't like change and who remember "the good ol' days" where you could spend a Sunday afternoon greasing nipples and playing with their points.
finpos
PostPosted: 13:12 - 09 Oct 2006    Post subject: Reply with quote
That's a very good point. A friend has a fuel injected bike, and for want of tinkering, has fitted one of these powercommander doofers to it. It's not clear to me what the little LED bargraph on it is representing, but seen as it's stuck on the very bottom LED at all points in the rev range, I'm not sure it's doing him any good.
Smile
finpos.
sunbear
PostPosted: 14:53 - 09 Oct 2006    Post subject: Reply with quote
Thanks fellas. Very imformative Thumbs Up
matthab
PostPosted: 21:06 - 09 Oct 2006    Post subject: Reply with quote
Well my injection has just failed in my PUG Jetforce 50 Tdsi, but its covered by warrenty so not that pissed off.
but i do notice it has more poke and bettwer fuel eccomoney (or however u spell it) compared to other peds!
Shame mines still restricted Sad
PostPosted: 22:19 - 09 Oct 2006    Post subject: Reply with quote
Fuel injection comes in many shapes and forms. Most car systems work off an air flow meter / air mass meter (with further fiddling based on feedback from the lamda probe). Reacts a bit more slowly.
Bikes often use systems mapped off the revs and the throttle position. Reacts very quickly to cack handed inputs.
Fuel cutoffs are quite common on injection systems. Cut the fuel totally when the throttle is shut.
Bikes are produced in far smaller number, so it works out more expensive to map them properly per unit sold (or cheaper and just don't bother mapping it properly). Honda seem to have particular problems mapping fuel injected bikes.
There are some hideously badly set up carbs on cars as well. Trying to get carbed cars through 70s US emissions rules was a nightmare (and injected cars were pretty rare, Alfa getting away with far more performance at the time by using mechanical fuel injection in the USA).
Also cars are a hell of a lot heavier so the effects of opening the throttle are far larger!
Jebus
PostPosted: 22:36 - 09 Oct 2006    Post subject: Reply with quote
the connection between the "driver" the throttle and the reaction from the vehicle is far more direct on a bike than a car, a car big and heavy so things happen a bit slower and get damped out a bit, on a bike got no weight to dampen the response out and the massive power to weight ratio also play a part. I am sure if you got in a massive hp car then you would think the fueling was a bit mad.
I like carbs, not from any riding experience but from how they work they respond to the air flowing thru them all the time and dont need a computer to tell them what todo, fuel injection is better and its just practice for the bike engines to get it right, ducati have got it well sorted apart from a bit of a lumpy engine low down but that may be because its a twin. honda seem to have problem because they problerly over engineer everything and want maximum fuel economy,
thats my 2p on it anyway
2nd time around Smile CBT: 8/9/11
125 Varadero
extreme3d
PostPosted: 01:26 - 10 Oct 2006    Post subject: Reply with quote
Perhaps one of the biggest perks to fuel injection is only really noticed on cold days. I just hit the engine start button and away I go. No having to mess around with chokes and/or waiting for the engine to warm up. The ECU takes care of all that for me Thumbs Up
Marci
PostPosted: 15:46 - 10 Oct 2006    Post subject: Reply with quote
From memory, you load up the power commander with 3x power maps. The LED indicates which map you're using. If it's always on the same one, then he's using the 1st programmed mapping.
Generally, you have one mapped for slow town riding, one mapped for blistering speed riding, and one mapped for summat else (track for instance), then a button on throttle allows you to flip from map to map. As you move thru the maps, the LED light should move to show which map you're on. Thass about it.
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
finpos
PostPosted: 16:05 - 10 Oct 2006    Post subject: Reply with quote
His has got a stacked bargraph consisting of about 15 leds. It does a fancy knight-rider type thing when you switch it on, then the bottom led lights up, unless he revs the bollocks off it, then the second one up occasionally flickers.
He's also saying it's started popping on the overrun, so I think he's spent a lot of cash to replicate very lean carbs on his fuel injection. You can't beat progress.
finpos.
Marci
PostPosted: 16:28 - 10 Oct 2006    Post subject: Reply with quote
Tell him to look at the manual...
https://www.powercommander.com/man_chp6_pg21.shtml
gixxersixx
PostPosted: 12:59 - 11 Oct 2006    Post subject: Reply with quote
One of the problems with fuel injection on bikes is due to engine size, the smaller the engine the smaller the quantity of fuel needed per cylinder. This is why its taken so long for bike manufacturers to get a system that works properly. Apparrently it wasnt just a case of making smaller injectors. Power commanders piggy back the standard ecu. The best way to set them up is with a dyno session. With the correct equipment the fueling and ignition can be set up so its as near as perfect for each part of the rev range.
We're all just born to die. So lets have some fun
gsxr6k1,pc,k&n,skimmed block,flowed head,yoshi gasket,cams,blue print,arrow system titanium can,quick shifter,gilles rear sets,ktech forks,ohlins shock,galfer waveys, -3front+4rear + other goodies
The last post was made 20 years, 2 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 3.19 - MySQL Queries: 13 - Page Size: 80.71 Kb
