| boyracer38 |
 boyracer38 L Plate Warrior
| finpos |
 finpos World Chat Champion
 Posted: 13:56 - 09 Oct 2006 Post subject: |
educated guess, so don't blame me etc.
switched live : black probe on battery -ve, red probe on candidate wire, measuring volts, should show 12v with ignition on and 0v with ignition off.
earth : black probe on battry -ve, red probe on candidate wire, measure resistance (ohms), should show zero ohms at all times.
neutral switch :
tach : to find the coil low tension wire, look at the coils, there should be two. each coil should have two small wires going to it. they should be a total if 3 different colours, i.e. one wire is the same colour on both coils. ignore this wire on both coils and connect your "tach" wire to any one of the other two.
EDITED neutral swich advice, which was bollocks!
finpos. |
| boyracer38 |
| finpos |
| boyracer38 |
 Posted: 09:51 - 12 Oct 2006 Post subject: Solved! |
I could not find an erath problem anywhere. In a last attempt i replaced my neutral switch and this seems to have resolved the issue!!
The DG8 is now installed, just got to 'teach' it my gears.
I will have a step by step guide done soon, if anyone is interested.
Jason  ____________________ ZXR 400 L |
The last post was made 20 years, 12 days ago. Instead of replying here, would creating a new thread be more useful? |
