Pitted cylinder head
mr jamez
PostPosted: 22:02 - 11 Oct 2006    Post subject: Pitted cylinder head Reply with quote
I have a KR1-S cylinder head sat here, which went off for machining due to debris damage to the combustion chamber (£30). The invoice states that it has been welded, but to me it just looks as if it has been skimmed and tidied up as all the pitting is still there.
I understand it can create 'hot spots' and assume it is important that the combustion chamber isn't like swiss cheese. Worth sending it back? (and complaining if they claim it has been welded)
Jebus
PostPosted: 22:13 - 11 Oct 2006    Post subject: Reply with quote
if the pitting is in the combustion chamber then as long as its not serious, then it wont matter. the skimming will of been on the "mating" surface were the head gasket would go, did you take this to a proper place that does lots of engine work or just a enginering company? id say go back and have a chat with them find out what has or hasnt been done.
Welding would only be used in rare cases on a cylinder head its a lot of heat and only really used for cracks etc, if they had to full the pitting with weld then they would need to do some very very very fancy machineing to get it back to how it used 2 be, and with it being a 2 stroke as well the combustion chamber is kinda critical to the running of the engine.
2nd time around Smile CBT: 8/9/11
125 Varadero
mr jamez
PostPosted: 22:17 - 11 Oct 2006    Post subject: Reply with quote
A well known two-stroke specialist, however I have seen barrels come back from there with shoddy work so thought I may as well check.
The last post was made 20 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 35.94 Kb
