| Sgt. Hobo |
 Sgt. Hobo Two Stroke Sniffer
| 2Smoke |
 2Smoke Crazy Courier
| gixxersixx |
 gixxersixx Trackday Trickster
 Posted: 11:56 - 12 Oct 2006 Post subject: |
is it "boging down" at the same revs in each gear? if not could be timing, if it is the same revs in all gears then carb/fuel settings, but check your plugs, could be dirty or porcelain cracked
What bike is it? ____________________ We're all just born to die. So lets have some fun
gsxr6k1,pc,k&n,skimmed block,flowed head,yoshi gasket,cams,blue print,arrow system titanium can,quick shifter,gilles rear sets,ktech forks,ohlins shock,galfer waveys, -3front+4rear + other goodies |
| the grim reaper |
 the grim reaper World Chat Champion
| Sgt. Hobo |
| finpos |
 finpos World Chat Champion
| Sgt. Hobo |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 17:04 - 12 Oct 2006 Post subject: |
if you do have a air leak in one of the boots. that would defently cause what your are describing.
while the bike is running get some wd40 and spray at the carb boots.
both before the carb and between the carb and the engine.
if the bike changes its revs at all then the boot has a hole and will need to be replaced(or if your budget you could always put a dab of silicone over the leak... thats only a temp fix though) ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| Sgt. Hobo |
| finpos |
| Sgt. Hobo |
| finpos |
 Posted: 17:54 - 12 Oct 2006 Post subject: |
That's a shame because it's really easy to fix
Next best guess would be general lean running then, which would also explain why it's hard to start.
finpos. |
| Sgt. Hobo |
| finpos |
| stinkwheel |
| finpos |
 Posted: 21:01 - 12 Oct 2006 Post subject: |
He makes a good point. Don't muck about with the carbs until you are certain the ignition is working. I didn't realise the bike had adjustable timing
finpos. |
| stinkwheel |
| gsxrpeak |
 gsxrpeak Trackday Trickster
| finpos |
| Pete. |
 Pete. Super Spammer
| stinkwheel |
 Posted: 19:36 - 13 Oct 2006 Post subject: |
| Sgt. Hobo |
| finpos |
 Posted: 23:36 - 14 Oct 2006 Post subject: |
Sgt Hobo:
If there's one thing more shonky than your bike, it's your camera. I can't make that out at all! Try a close up
finpos. |
| Pete. |
 Pete. Super Spammer
| Sgt. Hobo |
The last post was made 20 years, 14 days ago. Instead of replying here, would creating a new thread be more useful? |
