Opps..
mr.z
PostPosted: 18:31 - 14 Oct 2006    Post subject: Opps.. Reply with quote
https://img230.imageshack.us/img230/2015/img0431pu1.jpg]
Might explain some noises...
0ddball
PostPosted: 18:38 - 14 Oct 2006    Post subject: Reply with quote
How did they feel? I noticed when mine got that bad, if anything the braking power was stronger.
mr.z
PostPosted: 18:42 - 14 Oct 2006    Post subject: Reply with quote
To be honest i only took them off because it had started to bind (the rear brake) shitty design means the slideing pin seizes on cue every so many months, the material left on i think is basicly the binding material.. (also a nightmare to get the rubber parts back in together)
(the one on the left is spot on the wear limmit by the way)
Felt totally fine, but something was draging..
Rob-B
PostPosted: 19:35 - 14 Oct 2006    Post subject: Reply with quote
Shocked
paulthewitt
PostPosted: 10:26 - 16 Oct 2006    Post subject: Reply with quote
is there a law about how much brake pad there should be left?
Paul
Whosthedaddy
PostPosted: 10:38 - 16 Oct 2006    Post subject: Reply with quote
Paul
Its called common sense Laughing
My front may need changing sooner rather than later as one is worn more than the others which will lead to the aforementione pic.
You live and learn Wink
Nb
PostPosted: 11:45 - 16 Oct 2006    Post subject: Reply with quote
Paul
Not sure for bikes but for cars to pass the mot the brake pads need atleast 1.5mm of meat left on them.
0ddball
PostPosted: 13:02 - 16 Oct 2006    Post subject: Reply with quote
Too right. After you're stood there with a scored disc in your hand and are told the price of a new one you start to take a bit more care in checking them.
Itchy
PostPosted: 14:30 - 16 Oct 2006    Post subject: Reply with quote
Nb wrote:
Paul
isn't it supposed to be a visible amount?
Itchy
PostPosted: 14:32 - 16 Oct 2006    Post subject: Reply with quote
You ain't seen worn though , somebody posted here recently G maybe about his brake pads that were paper thin,
worn brake pads are super for stoppies though , I used to be able to stoppie loads but with new ones I tend to come flying off.
Nb
PostPosted: 14:45 - 16 Oct 2006    Post subject: Reply with quote
i) Brake linings or pads (other than sintered pads) less than 1.5mm thick at any point
(ii) Sintered brake pads less than 1mm thick at any point Thumbs Up
DEN MONKEY
PostPosted: 14:57 - 16 Oct 2006    Post subject: Reply with quote
Yes its called inertia
meh
Gazdaman
I did a trackday!!!
PostPosted: 11:25 - 17 Oct 2006    Post subject: Reply with quote
You'll fail an MOT if you havn't got enough meat.
Seen it done.
Gaz
The last post was made 19 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.34 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 79.43 Kb
