NSR125R Carb Tubes????
KevShek
PostPosted: 23:30 - 14 Oct 2006    Post subject: NSR125R Carb Tubes???? Reply with quote
Can anyone help me out with this. I removed the carb the other day and had a look at the reeds, while fiddling about and refitting, i noticed 3 tubes (black rubber about 5mm OD, 3mm ID) Hanging about. I believed these to be numbers 29, 30 and 31 on the diagram below.
Are these just venting tubes?
https://www.nsr125.com/schem13.jpg
alains
PostPosted: 00:15 - 15 Oct 2006    Post subject: Reply with quote
in fact it's 5 pipes coming in the carb . 1 black rubber which is the fuel feed , 1 black rubber (less thicker) which is oil feed , 2 plastic thin pipes coming on top which are breathers pipe (on each side) , 1 about the same under the float chamber which is a purge exit
KevShek
PostPosted: 00:26 - 15 Oct 2006    Post subject: Reply with quote
thanks alains, you are a wealth of knowledge, it was those latter 3 you mentioned i was refering to, and i thought as much.
you know the plastic tray which sits over the inlet/card, which holds all the wiring inplace, can i just remove that and leave it off? cos it gets in the way when working on the bike/carb.
alains
PostPosted: 00:35 - 15 Oct 2006    Post subject: Reply with quote
i'm afraid no , because it holds the servo-motor and all connectors are packed on the left . if you find a DIY thing to hold the servo it's possible .
KevShek
PostPosted: 00:40 - 15 Oct 2006    Post subject: Reply with quote
yeah, i have thought about doing that. Is that directional? or should i say does it have to sit that way up in that position? just before i move it and do some damage.
alains
PostPosted: 01:00 - 15 Oct 2006    Post subject: Reply with quote
it must stay as it is actually . the tray is held on 2 pins on the right side , may be you can thread these pins ans use them to fix a plate where you can fix the servo on the same position as it is now
KevShek
PostPosted: 01:02 - 15 Oct 2006    Post subject: Reply with quote
ok, will consider it. It would make accessing the carb and reeds more easily for future upgrades.
code guru
PostPosted: 01:42 - 15 Oct 2006    Post subject: Reply with quote
i aint got that plate thing and my servo sits next 2 the air box and its fine.
alains
PostPosted: 01:53 - 15 Oct 2006    Post subject: Reply with quote
put a pic here , we shall see
code guru
PostPosted: 09:20 - 15 Oct 2006    Post subject: Reply with quote
well the funny thing is i cant find the 8 mm allen key to open my tank and im going 2 work now and a guy is comeing 2day 2 buy my bike . my dad is gona sort all the paper work go so ill miss the nsr Sad if i do find it tho with in the next 45 min i will take a pic
alains
PostPosted: 09:33 - 15 Oct 2006    Post subject: Reply with quote
why dont you have your tool box under your seat ?
code guru
PostPosted: 02:30 - 21 Oct 2006    Post subject: Reply with quote
lo coz i lost my net on sunday as well and i sold my nsr on sunday but i got the pic tho.
i did have tools under my seat but i was working on my new bike (cbr400) and i had 2 use that alen key to take my seat of 2 take my tank of ect. anyway i will post a pic of it 2moro. theres nothink wrong if its just sitting there. just make sure the cables aint stretched ect
alains
PostPosted: 09:55 - 21 Oct 2006    Post subject: Reply with quote
give to cesar what's belong to julius
code guru
PostPosted: 23:34 - 21 Oct 2006    Post subject: Reply with quote
kk here is the pic
the pink stuff on the air box is fiber glass because the prev person tought it was fully 2 drill holes on the airbox Laughing
KevShek
PostPosted: 23:38 - 21 Oct 2006    Post subject: Reply with quote
that was one thing i was gonna ask, with all the new mods im fitting, gianelli exhaust, uprated jets, reeds, will i need any modifications to my airbox?
YZF R125
code guru
PostPosted: 00:38 - 22 Oct 2006    Post subject: Reply with quote
wouldnt recomend a k&n but u can drill 2 holes on your air box but not ontop. alains has a tut about it. i did have it but dont have it anymore
KevShek
PostPosted: 09:07 - 22 Oct 2006    Post subject: Reply with quote
i think i may have seen a picture of it somewhere but im not 100% if its the same one. I couldnt quite figure out which part of the airbox it was, unless it was the top.
YZF R125
code guru
PostPosted: 09:32 - 22 Oct 2006    Post subject: Reply with quote
na i think u take the top part of the air box of and then u drill 2 small holes on the right hand side were the air comes in from i think and u put 2 small pipes? i didnt add the 2 small pipes on mine and it was running fine with an arrow exhaust and 138 main jet
KevShek
PostPosted: 10:08 - 22 Oct 2006    Post subject: Reply with quote
it definately isnt the same pic then, cos the one i seen had loadsa holes all over this particular part of the box. ill post it up if i can find it.
YZF R125
KevShek
PostPosted: 10:16 - 22 Oct 2006    Post subject: Reply with quote
hold on, it was alains guide afterall, there are 3 solutions on there, the second one is what i was refering too. On his airbox, there is a grid on the top next to the collector tray. That has all been drilled out.
The 3rd on is the tube/hole thing you mentioned.
I was thinking i could use some large bore hose of some sort anf continue it from the air duct tube that comes from the front. Good idea or bad? as i dont wanna be scooping up water if it rains.
YZF R125
The last post was made 19 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.15 - MySQL Queries: 15 - Page Size: 106.34 Kb
