Torx (? safety) screw help
syl
PostPosted: 17:44 - 15 Oct 2006    Post subject: Torx (? safety) screw help Reply with quote
I need some advice on removing a screw. Now this isn't from a bike, but that doesn't make a great deal of difference to the advice I guess.
I bought a new hedge trimmer in the summer. Father-in-law kindly offered to trim the hedge whilst he was down here recently and prompty cut through the cable about 12 inches from the tool itself. I know I can get a connector (permenant or quick fit) however I'd rather just open the trimmer and refit the wire.
I finally got round to buying a screwdriver that fits (torx 20) and removed all of the screws with a screwdriver from Halfords
https://www.knifekits.com/store/images/screws/256fht-420-155-6.jpg
Bar one. That screw has a prong in the middle, rather like this:
https://www.pavoniexpress.com/torxscrew.jpg
and my screwdriver has a flat end so it can't make contact with the torx pattern. Maybe this is some kind of anti-tamper screw? Anyway, I need a screwdriver like this:
https://upload.wikimedia.org/wikipedia/ja/c/c2/TorxScrew.jpg
with the little hole in the middle.
Any ideas? It has to be a scredriver rather than a socket as the screw is down a hole which is only just big enough to admit a screwdriver diameter.
Current bike: Kawasaki Z750S
Whosthedaddy
PostPosted: 17:51 - 15 Oct 2006    Post subject: Reply with quote
Ford have those star shaped heads with a raised middle on their interior fixings. I tried to change a seat belt in the wifes Ka and found it impossible without the correct fitting head. I suspect that they are a form of anti tampering measure, so a head may be hard to come by.
PostPosted: 17:52 - 15 Oct 2006    Post subject: Reply with quote
It is just the tamperproof variety (there are similar allen key bolts). You probably could just drill the pin away but really you need the tamperproof torx bits. Try a few of the local autofactors and hopefully one of them will have them in.
syl
PostPosted: 17:56 - 15 Oct 2006    Post subject: Reply with quote
Thanks, searched on T20 tamperproof and found this site:
https://www.tooled-up.com/
which seems to stock it for a couple of quid. Thanks to you, I'll have to order a load of other stuff to make the postage worthwhile! Rolling Eyes
Thanks Thumbs Up
irving
Question
loply
PostPosted: 18:22 - 15 Oct 2006    Post subject: Reply with quote
Tooled-Up.com - Very good tool supplier, the delivery on small items is like 50p for a drill bit or £2.50 for a socket wrench.
Yamaha SZR660 Caution to the wind, the throttle pinned!
PostPosted: 18:29 - 15 Oct 2006    Post subject: Reply with quote
You ever up Reading way (closeish according to the map)? I've got laods of spare screwdriver bits, including security ones.
You're welcome to nab what you need.
KevShek
PostPosted: 19:40 - 15 Oct 2006    Post subject: Reply with quote
depending on the size, i have in the past just snapped of the little stud using a flat screw driver, then simply used a torx bit. not much security there!
wait till you come across the ones with a 5 pointed star an stud. i couldnt find anything to remove that, except some mole grips!
YZF R125
firefox
PostPosted: 20:06 - 15 Oct 2006    Post subject: Reply with quote
halfords sell them, i got mine from there Thumbs Up
bye bye gti <^>( ' . ' )<^>
*officer* what caused the crash ? *firefox* you see that wall up there sir ?
*officer* yes what about it *firefox* i tooted my horn but it refused to move i had to teach it a lesson.
Walloper
PostPosted: 20:12 - 15 Oct 2006    Post subject: Reply with quote
You should get the bcf safety award for effort to repair the trimmer flex. Thumbs Up
Most folk would think nothing of a Twist 'n' Tape repair.
Best of luck.
Black Knight
PostPosted: 21:06 - 15 Oct 2006    Post subject: Reply with quote
I'd just repair the cable mate!
I tried to refit a wire to a hedge trimmer recently, managed to remove the billion screws needed only for neumorous springs to pop out never to return!
I haistily reassembeled it, returned it to the shop and exchanged it for a new un!
Yeah, I know i'll go to hell but my hedge was getting severely out of control!
Where does a turn end? 'Where you can do anything with the gas you want to, where you are brave again, where your attention is free from the turn, where you are sure you can do it better next time; that's the end' - Keith Code.
Walloper
PostPosted: 21:15 - 15 Oct 2006    Post subject: Reply with quote
Immoral, Unscrupulus, Devious and dead Jammy Laughing
syl
PostPosted: 21:47 - 15 Oct 2006    Post subject: Reply with quote
Not the one I bought from there this afternoon (read entire original post)
firefox
PostPosted: 21:55 - 15 Oct 2006    Post subject: Reply with quote
the bits can fit into screw drivers though
loply
PostPosted: 22:37 - 15 Oct 2006    Post subject: Reply with quote
So that's why this damn thing never worked!
alone
PostPosted: 23:30 - 15 Oct 2006    Post subject: Reply with quote
I used to work installing Door Access Panels outside buildings along with other security equipment, came across them all the time, a pair of thin nose pliers work a treat.
Good luck.
firefox
PostPosted: 11:24 - 16 Oct 2006    Post subject: Reply with quote
Good luck.
i fit them we just use 2 screws lol and a plastic cover Rolling Eyes thats adt for you Laughing
The last post was made 19 years, 362 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 95.97 Kb
