GPZ/ER5 exhaust.
Irezumi aka Reuben
Carrot Top
PostPosted: 11:57 - 15 Oct 2006    Post subject: GPZ/ER5 exhaust. Reply with quote
My Nexxus exhaust system is beggining to crack where the end can join's the main exhaust pipe (downpipe?). I am going to replace the system, will get a weld bodged on but this will make it more succeptable to corrosion so will need replacing sooner or later.
What I would like to know is does an original exhaust from a Kawasaki ER-5 fit onto a GPZ500s D without any modification bar to the rear hanger, will it fit under the belly pan etc?
Thanks for any help.
P.S. I'm after a GPZ exhaust system if anyone knows of one going spare, original or aftermarket in good condition.
PostPosted: 18:43 - 15 Oct 2006    Post subject: Reply with quote
Mine cracked round that weld and fell off after a crash about eight years ago. I got it welded back on and it is still solid and in use on the bike (albeit a trifle tatty looking now).
extreme3d
PostPosted: 20:12 - 15 Oct 2006    Post subject: Reply with quote
As far as I'm aware an ER-5 system will not fit onto a GPZ and visa versa.
Also even if you did manage to bodge it on, it wouldn't do the GPZ engine much good until you got the engine mixture changed to match it. The GPZ is a good 10Hp more powerful than the ER-5.
I would get it welded then paint the weld with some high temperature paint. This should help protect the external surface at least and make it last a bit longer.
edd
PostPosted: 01:32 - 16 Oct 2006    Post subject: Reply with quote
Why would it be more likely to corrode? Im assuming the pipe is stainless? Stainless welds wont corrode any more than the existing ones holding it together. Take it to an engineering firm who do stainless welding.
Bluespark Automotive - Diesel Tuning for Performance and Economy
Irezumi aka Reuben
Carrot Top
PostPosted: 16:49 - 16 Oct 2006    Post subject: Reply with quote
Could do. Or my old man can bodge it who doesnt do stainless welding. Not a bodge, but not the required weld, so will be exposed to corrosion. May just do that then paint it with heat resistant paint to avoid the onset of corrosion, it isn't a massie crack, just hairline at the minute, but if not dealth with will go.
Thanks for the advice, shall continue to scour ebay as well. Smile
PostPosted: 21:01 - 16 Oct 2006    Post subject: Reply with quote
Well my motad nexxus is made of chromed mild steel and I can assure you it rusts just fine.
The last post was made 20 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 47.08 Kb
