Removing forks,
Itchy
PostPosted: 21:32 - 15 Oct 2006    Post subject: Removing forks, Reply with quote
I'm a bit of confusion here , in that I have a rear stand and a front stand which the forks rest on , thing is I want to remove the front forks to replace the fork seals (and bushes too Sickpup).
Thing is since I'm removing the front forks this makes my front stand useless so how do I prop up the front? , my tyre man used some sort of £££££ hydraulic lift of some sort and while I was making a move on a scooter girl who was waiting too , he had trouble positioning it.
I've looked in my haynes and it says make some sort of wooden box for the engine case to sit on. while you remove the front end.
I can't justify buying a hydralic lift (£2-300) and my breaker says NTV centre stands are as rare as rocking horse shite.
My mind is currently thinking since I've got 3 car jacks.... maybe a huge block of wood onto of those can sort of work as a cheapo bike lift (a car I bought came with 3 identical jacks). would this work and are there any alternatives? (me thinks taking our one fork at a time = twisting)
any suggestions?
Ta
any suggestions?.
PostPosted: 21:41 - 15 Oct 2006    Post subject: Reply with quote
Personally if I cannot be bothered to did out the engine hoist (it is a heavy bugger) then on a centre stand (or rear paddock stand) and a pair of axle stands at the front of the engine.
Jacks can also work, except they can start to loose a bit of pressure / height.
irving
PostPosted: 21:44 - 15 Oct 2006    Post subject: Reply with quote
Question
Whosthedaddy
PostPosted: 21:45 - 15 Oct 2006    Post subject: Reply with quote
Siggi wrote:
Use a car-jack and a flat piece of wood to jack the bike under the pipes. Ideally you should do this in conjunction with a stand that supports the rear-end from the swinging-arm pivot, as a paddock stand leaves rather too much weight on the pipes (I have done it but wasn't happy about it...I use an Abba stand for the rear now).
The wood and jack idea made my FZR wobble all ove the place as the pipes were in the way, I just gingerly jacked the bike up and then used 2 axle stands under the frame. They do move a little as the weight shifts but remained secure enough.
The Abba stand does look a nice little idea Thumbs Up
The last post was made 20 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 42.58 Kb
