Oil and water mixed
GSXReater
PostPosted: 15:50 - 23 Sep 2006    Post subject: Oil and water mixed Reply with quote
I bought a Honda CR250 with problems and one big problem is that it seem the coolant is mixing with the oil resulting in grey goo coming out of the carb overflow.
What do i need to do? Change head gasket? Water pump gasket?
Cheers.
PostPosted: 15:58 - 23 Sep 2006    Post subject: Reply with quote
Struggle to think how water can get from the engine back to the carb and then out of the overflow.
Most common problem on a 2 stroke with water in the gearbox (and so possibly coming out of the crankcase breather) is a damaged water pump seal.
GSXReater
PostPosted: 16:13 - 23 Sep 2006    Post subject: Reply with quote
If that is the case then is it just a case of changing that gasket and im good to go or what else needs to be done to ensure the bike's running properly?
PostPosted: 18:18 - 23 Sep 2006    Post subject: Reply with quote
Yes, change the seal (presume the water pump is under the clutch cover). Also need to drain the gearbox oil and fill with fresh stuff (probably worth doing this a few times over a short period of time to flush out the remaining water).
nicky284
PostPosted: 11:37 - 16 Oct 2006    Post subject: Reply with quote
what do you think of your cr250
have you had a chance to ride it yet, i,ve been looking at these thinking about racing motorcross
fixed your problem with it yet
GSXReater
PostPosted: 18:03 - 16 Oct 2006    Post subject: Reply with quote
Nicky, i havent fixed it yet but i had a go on my friends RM250. What a rush!!! I was huffing and puffing after 10 minutes of riding, its true, you have to be fit to ride a moto x bike properly.
I really need to get stuck in with getting my CR fixed.
PostPosted: 19:43 - 16 Oct 2006    Post subject: Reply with quote
When you change the oil, flush it around several times until it's coming out looking like oil, rather than looking milky. Use cheap car oil for this, when I drowned my XR it needed flushing through 7 times so you don't really want to be using expensive oil.
cagiva gezzer
PostPosted: 21:12 - 16 Oct 2006    Post subject: Reply with quote
mates CR250 had a holed waterpump housing. Only a pin hole from corrosion, but need a whole new RH casing.
The last post was made 19 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 3.38 - MySQL Queries: 13 - Page Size: 56.72 Kb
