| shammon |
 shammon World Chat Champion
| 0ddball |
 0ddball World Chat Champion
| irving |
 irving Traffic Copper
 Posted: 22:53 - 15 Oct 2006 Post subject: |
| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 23:02 - 15 Oct 2006 Post subject: |
Sounds like the altenator to me. The ZXR had a naff one and left e stranded many a time.
My bike would start again by jumping it, yet cut out again if the lights were turned on, or a few yards down the road. Check the bushes and belt if present as these may need changing. ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| shammon |
| shammon |
 Posted: 01:27 - 16 Oct 2006 Post subject: |
Ended up tonight getting it stripped, all conections ok then checked voltage when running was 12.5
Will need to check the rectifier or the alternator tomorow, thanks for the advice. i have a manual on the bike but if im stuck il pop back on here  ____________________ YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı |
| finpos |
 finpos World Chat Champion
| irving |
 Posted: 12:21 - 16 Oct 2006 Post subject: |
| Walloper |
 Walloper Super Spammer
 Posted: 12:53 - 16 Oct 2006 Post subject: |
'Load Test' the battery.
Voltmeter across + & - terminals.
Crank the Engine/Engage the Starter.
Read Voltage.
Should hold 10.5 11.5 volts for a few seconds and gradualy fall to lower value.
If it 'Dives' for low volts then the Battery is Goosed. (Unlikely on a New Battery)
Probably got a charging fault.
This would also knacker a good battery by Hydration Cycles etc.
For your perusal:
https://www.cdtechno.com/cd/library/manual/h199/Avoid_Battery_Degradation.htm ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| irving |
 Posted: 15:18 - 16 Oct 2006 Post subject: |
| shammon |
 Posted: 18:56 - 16 Oct 2006 Post subject: |
Update:
Discovered the alternator joining wire clip was filthy so cleaned it. battery was 12.5 with the engine off so started up ok so far out put on battery was now a healthy 14.3 volts thern i turned on the lights....
It dropped to 12.3 then put on main beam 12v then full 11.7v
now it was making sense i rode yesterday with my lights on full as it was foggy. so the alternator was not charging the battery.
So any one know why this is? is it a regulator fault?
Speaking of the regulator it was very hot in the space of 5 mins after starting. ____________________ YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı |
| finpos |
| shammon |
| irving |
 Posted: 19:19 - 16 Oct 2006 Post subject: |
| irving |
 Posted: 19:23 - 16 Oct 2006 Post subject: |
| Whosthedaddy |
 Posted: 16:21 - 17 Oct 2006 Post subject: |
Maybe its down to worn bushes not making adequate contact. Not sure whether you can buy them separate as the ZXR cam as a sealed type unit. ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| shammon |
 Posted: 17:34 - 21 Oct 2006 Post subject: |
Rectifer was the cause.
running now on a good feed from the alternator on 13.5 will all lights on and at idle etc so all round prob fixed!.
Cost £40 for the rectifier which was the cheapest and found this on ebay(xj600 pre diversion) 5 min job to fix as its just under the left panel. Thanks to all for the input
Hope some one else finds this usefull.  ____________________ YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı |
The last post was made 19 years, 344 days ago. Instead of replying here, would creating a new thread be more useful? |
