adjust idle on NSR125
blamchez
PostPosted: 17:01 - 18 Oct 2006    Post subject: adjust idle on NSR125 Reply with quote
the idle has dropped on bike since i last worked on it. how do i raise it, wheres the screw that does this?
cheers
50cc honda ---> CG125 ---> 125cc jap scooter ---> NSR125 ---> NC30 ---> CB500 ---> ZX7R
T1z3R
PostPosted: 17:03 - 18 Oct 2006    Post subject: Reply with quote
should be on the left side of the carb between the body and the float bowl.
duck my sick!
blamchez
PostPosted: 17:15 - 18 Oct 2006    Post subject: Reply with quote
ok great. i had a suspicion it was there.
cheers matey
Jebus
PostPosted: 17:43 - 18 Oct 2006    Post subject: Reply with quote
remember everything happens for a reason, do you know why the idle has changed on your bike? there may be somthing causeing it that you should have a hunt for first.
2nd time around Smile CBT: 8/9/11
125 Varadero
alains
PostPosted: 18:37 - 18 Oct 2006    Post subject: Reply with quote
if your bike is 1993 and later (JC22) the screws are on the right if before (JC20) they are on the left . the pilot is the most in front , should be set at 2 1/2 turn out
then after 5-10 mpn warming the idle screw should be set at 1400 RPM +-100 ( i use to set mine at 1500)
before that , you should clean tank (tap also) , air box filter foam and slightly oil it (see workshop manual) and the carb
when the bike change of sound or performance , surely it needs cleaning Very Happy
The last post was made 19 years, 356 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 43.35 Kb
