| BeanieBiker |
 BeanieBiker L Plate Warrior
| irving |
 irving Traffic Copper
 Posted: 17:34 - 19 Oct 2006 Post subject: |
| BeanieBiker |
| befdelta7 |
 befdelta7 Brolly Dolly
| rickyfazer |
 rickyfazer Two Stroke Sniffer
 Posted: 12:39 - 20 Oct 2006 Post subject: |
When you turn your ignition on do's the flashing LED on the dash go out? If not,the immobiliser has locked itself.
Seems to be a common fault with Speedfights. Replacing the CDI alone will not help as it needs to be matched to its original ignition barrel and the round plastic sensor which clips around the barrel and plugs in to the CDI.
If the immobiliser has locked out and you still have the original keys(the red one with the chip in it) then there are places,probably an official Peugeot dealer who can reprogramme it.
If you replace the CDI,you must also buy its matching ignition barrel and sensor. These go on ebay for about £100.
Alternatively you can buy a new non immobiliser cdi designed specifically to bypass the immobiler.
is yours an ACI100 unit like this one?
https://www.cdiunits.co.uk/images/moped3_big.jpg
If so you can replace it with a bypass one from www.mopedcdiunits.co.uk for £97 ____________________ never wipe yer arse wi a broken bottle ! |
The last post was made 19 years, 348 days ago. Instead of replying here, would creating a new thread be more useful? |
