2001 NSR Won't Switch Off!
SilvaRizla
PostPosted: 18:50 - 19 Oct 2006    Post subject: 2001 NSR Won't Switch Off! Reply with quote
When I turn the ignition off on my NSR, the lights go off, the rev needle and temp needle drop down but the engine keeps running, does anybody know how to sort this out? The only way I can switch it off is either to stall it or put it in gear with the stand down.
Thanks
Silva
I'm Ivan Dobski the Meatsafe Murderer only I never done it, I only said that I done it so they'd take the truncheon out of my bottom
Whosthedaddy
PostPosted: 19:09 - 19 Oct 2006    Post subject: Reply with quote
I had a similar problem with my old Mini, it was caused by a sticking throttle cable.
SilvaRizla
PostPosted: 19:10 - 19 Oct 2006    Post subject: Reply with quote
Wouldn't that mean that the revs will increase and it won't idle properly though?
Whosthedaddy
PostPosted: 19:12 - 19 Oct 2006    Post subject: Reply with quote
It would all depend in where the cable was binding, if it was at the final few mm then it may just prevent the revs from dropping keeping the engine going.
irving
PostPosted: 19:15 - 19 Oct 2006    Post subject: Reply with quote
Arrow
SilvaRizla
PostPosted: 19:18 - 19 Oct 2006    Post subject: Reply with quote
The switch is stiff, you have to jiggle it to turn it sometimes. So you think that is the culpret?
irving
PostPosted: 19:20 - 19 Oct 2006    Post subject: Reply with quote
Arrow
Jebus
PostPosted: 19:23 - 19 Oct 2006    Post subject: Reply with quote
does the kill switch stop the engine? if that ok then it most likly a dodgy contact or faulty switch.
2nd time around Smile CBT: 8/9/11
125 Varadero
SilvaRizla
PostPosted: 19:26 - 19 Oct 2006    Post subject: Reply with quote
I haven't tried the kill switch, I've heard you're not really supposed to because it causes damage
finpos
PostPosted: 19:37 - 19 Oct 2006    Post subject: Reply with quote
Depends on how the bike is wired up - either the kill circuit isn't working (normally, the kill switch circuit works in exactly the same as your non-functional circuit that goes through the ignition switch), or it's been hotwired in the past Smile
finpos.
irving
PostPosted: 19:47 - 19 Oct 2006    Post subject: Reply with quote
Arrow
extreme3d
PostPosted: 21:17 - 19 Oct 2006    Post subject: Reply with quote
I've stopped every bike I've ever owned every day with the engine kill switch, never done mine any harm yet. Why should it, it just stops the engine ignition in the same way as turning the key, certainly on a fuel injected bike*.
*It's not a good idea to flick the kill switch when moving on a carbed bike, as whilst it turns off the ignition it doesn't turn off the fueling. Means fuel is still flowing through the engine as it 'free wheels' and this can cause damage to a catalytic convertor if one is fitted and/or will shoot blue flames out of the back when you turn the switch back on.
irving
PostPosted: 21:36 - 19 Oct 2006    Post subject: Reply with quote
Arrow
KevShek
PostPosted: 21:41 - 19 Oct 2006    Post subject: Reply with quote
shooting flames??? you serious??? ive gotta try this Very Happy
YZF R125
Jebus
PostPosted: 21:50 - 19 Oct 2006    Post subject: Reply with quote
HEHEEHEHE that sounds ace i gotta try this! Thumbs Up Thumbs Up Cool
125 Varadero
KevShek
PostPosted: 21:53 - 19 Oct 2006    Post subject: Reply with quote
so what we thinkin here???? drive along, coast, clutch in, kill switch, throttle up! then hit START??
YZF R125
irving
PostPosted: 22:08 - 19 Oct 2006    Post subject: Reply with quote
Arrow
ROB_NSR
PostPosted: 22:11 - 19 Oct 2006    Post subject: Reply with quote
More or less, but dont pull the clutch in, just ride along, kill switch, give a bit rev maybe then killswitch back on and BANG!!!
Used to do it in a couple of my old cars!
You have to have the clutch out so the engine is still turning and drawing in fuel
CBT: PASSED!! THEORY: PASSED!! PRACTICAL: PASSED!!
PostPosted: 22:31 - 19 Oct 2006    Post subject: Reply with quote
I would suggest that you have a bad earth connection from the ignition switch or the switch itself is faulty.
alains
PostPosted: 22:51 - 19 Oct 2006    Post subject: Reply with quote
i have nor read all your answers , but i think it's due to a loose contact on the CDI , check your wiring there
Whosthedaddy
PostPosted: 00:21 - 20 Oct 2006    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=73602&highlight=backfiring
The last post was made 19 years, 353 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 109.2 Kb
