can i derestrict imported cb125t .
gazzzzzzz
PostPosted: 21:49 - 19 Oct 2006    Post subject: can i derestrict imported cb125t . Reply with quote
newbie needs help. Laughing
i bought my 04 reg cb125t from ebay in july, moving up from scooters to practice for my test.
i dont know and cant find much info on this bike, the max speed i can reach is 50mph. my old scoot done 75mph Crying or Very sad
does anyone know if my honda needs derestriced or is it just a slow bike.
thanks for any help.
gary
beatnck
PostPosted: 21:53 - 19 Oct 2006    Post subject: Reply with quote
no its not restricted, just a slow bike im afraid! its only really 125 2 strokes like rs's and mito's that are restricted. Thumbs Up
PostPosted: 22:42 - 19 Oct 2006    Post subject: Reply with quote
Should do 65mph on one of those. They were common in the UK in the mid 1980's and mine would certainly do 65. The really early ones (1970's) were flying machines which would do a genuine 80mph but they were restricted to comply with learner regulations.
Before you ask, that restriction is at a 'nut and bolt' level of major engine componants (valve size, cam profile and advance curve) so no you can't undo it. Think of the bike as more having been totally redesigned to produce less power.
None the less, I would expect your one to be perfectly capable of 60-65mph. Are you taking it right up to the redline in every gear? Don't worry about damaging it, the really early ones had the redline at 11,500rpm and they were in a higher state of tune so you're not going to blow it up doing 10k+ rpm.
Does it fire up nicely? How long is the lag before the second cylinder kicks in when you start it? Rev up fast and clean off the throttle without stuttering or lagging?
PostPosted: 00:27 - 20 Oct 2006    Post subject: Reply with quote
You're right the early ones were real flyers! My brother had one, ultimately died due to poor top-end oiling (or maintenance). He got the later TDC model after that bu tit was pants compared to the first. Can't even use early parts to make the later ones go faster either because they changed the piston configuration.
gazzzzzzz
PostPosted: 20:31 - 21 Oct 2006    Post subject: Reply with quote
it takes a while and a couple of attempts to start up, it usually cuts out if i give it a rev. but runs and starts fine once warmed up.
could i have carb problems causing my 50mph?
sorry i dont know what you mean by lag and second cylinder (newbie) Sad
sometimes if driving along about 30-40mph i feel a slight loss of power, and need to give it more revs.
i might take it to a garage to see if they can look over it.
thanks for your info by the way
gary
PostPosted: 20:42 - 21 Oct 2006    Post subject: Reply with quote
It might be the carbs need to be balanced. There are two of them and if they aren't functioning symetrically, one side of the engine will 'hold back' the other side.
On those honda twins, this is usually accompanied by poor throttle response and one cylinder firing up first when you start the engine with the other 'lagging' behind it (you usually hear it 'kick-in' about 5-10 seconds after the engine starts from cold).
They are a total bastard to balance so a mechanic may well be a good plan in this case.
mchaggis
PostPosted: 20:46 - 21 Oct 2006    Post subject: Reply with quote
Forgive me for my insolence, but other than what looks like a Honda badge, that looks a bit like a single cylinder Chinese 125 with two exhausts. I think I recognise the engine - it looks the same as what I had on mine, which was most definately not a parallel twin.
Even so assuming that it is what I think it is, in decent nick one of those should reach 60.
I must not be a troll...
Mmmm, Guinness
beatnck
PostPosted: 20:49 - 21 Oct 2006    Post subject: Reply with quote
my first bike was a cb125, it had cut down exhaust and a custom tank - sounded really good, if not a little loud! it was a 1976 model, if i remember rightly i used to get about 70-75 mph out of it when conditions allowed
PostPosted: 20:57 - 21 Oct 2006    Post subject: Reply with quote
Well it is a lot newer, but I have owned a 1977 CB125T1 and a 1986 CB125TDC and they were both paralell twins. It looks identical to my TDC with the exception of the wheels (cast alloy replacing the comstars mine had).
They did make a single cylinder version called the CB125S. As far as I'm aware, the 'T' stands for 'twin' and the 'S' stands for 'single' but you never know with the Japanese
mchaggis
PostPosted: 21:09 - 21 Oct 2006    Post subject: Reply with quote
https://i7.photobucket.com/albums/y254/mchaggis234/hongdou14.jpg
https://i7.photobucket.com/albums/y254/mchaggis234/hongdou13.jpg
That's my Chinese mistake for comparison.
The way the exhausts point into the same cylinder and the single spark plug lead (there's not one on the left hand side) point to something odd going on if this was sold as a twin.
Mmmm, Guinness
PostPosted: 21:13 - 21 Oct 2006    Post subject: Reply with quote
I think McHaggis might be right. Looks like CB125T chassis with a different engine in it.
Ferret
PostPosted: 21:46 - 21 Oct 2006    Post subject: Reply with quote
Looks like it has a single cylinder chinese engine in it with the other exhaust there for show.
Could be wrong
Ta
Ferret
PostPosted: 22:01 - 21 Oct 2006    Post subject: Reply with quote
Now you come to mention it, the engine does look different. I found this picture of a CB125T which is what I would have expected to see.
https://had0.big.ous.ac.jp/~hada/students/zemi01/ochi/cb125t.jpg
gazzzzzzz
PostPosted: 14:24 - 25 Oct 2006    Post subject: Reply with quote
hmmm,
well i dont know what the engine is from. (not very good if i need parts)
on the reciept from the garage it states (cb125t single)
i will let you pros have a look, here is some pics
gazz
Grubby
PostPosted: 19:48 - 25 Oct 2006    Post subject: Reply with quote
I'm a bit of an expert on these.....(Hangs head in shame)
The early ones were faster because the firing order was different to the later models. On the early ones they had more than the poxy 12 bhp you poor buggers are restricted to nowadays as the pistons fired in pairs (Big bang engine) & they used to do 85 MPH. The later ones fired as a normal twin does & only reach 70MPH on a good run.
The top ends are indeed well known for poor oiling & the cam is known for rattling itself loose from the head.
These ain't bad bikes.....But they are fairly hefty things compared to a modern Honda 125 which will eat it for brekkie on handling, braking & acceleration.
The other thing they were well known for was that the centre stands used to wear really badly.
I am me & you are he & we are all together. See how they run like pigs from a gun!
hmmmnz
PostPosted: 19:49 - 25 Oct 2006    Post subject: Reply with quote
i suspect that its a chinese bike with honda decals.
the humans are dead
I kick arse for the lord
Grubby
PostPosted: 19:54 - 25 Oct 2006    Post subject: Reply with quote
I've just had a closer look at your pics....changed computers here at work for one with a bigger screen....that ain't a Honda CB125T engine mate. It's one of those Chinese jobbies. Ride for a year, throw it away.
Gazdaman
I did a trackday!!!
PostPosted: 14:31 - 26 Oct 2006    Post subject: Reply with quote
Does it have two plug leads would be the giveaway?
Gaz
finpos
PostPosted: 14:49 - 26 Oct 2006    Post subject: Reply with quote
Might just be me, but that engine seems to have a faint whiff of CG125 about it (clagged-on twin exhaust outlet excepted).
finpos.
gazzzzzzz
PostPosted: 17:41 - 26 Oct 2006    Post subject: Reply with quote
well, thanks everyone for the advice.
as i said i only bought the bike to get some practice for my test next summer, then i will sell it on. but apart from not going past 50mph it is still a good easy bike to learn on.
cheers everyone
gary
The last post was made 19 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 120.99 Kb
