Changing the Brake lines.....
dgk13
PostPosted: 07:14 - 20 Oct 2006    Post subject: Changing the Brake lines..... Reply with quote
I've bought a set of braided lines for my mito, would it be okay to give it a DIY job? Or is it better to pay someone to do it? Just want to make sure its going to be done right either way, being the second most important part of bike, don't want them to fail!
Is it as simple as taking the old lines off, replacing them, then topping the fluid up and bedding them in?
Thanks
Honda powwwwerrrr
irving
PostPosted: 08:45 - 20 Oct 2006    Post subject: Reply with quote
Arrow
KatOwner
PostPosted: 19:26 - 20 Oct 2006    Post subject: Reply with quote
It's the sort of job that any reasonably competent DIY spanner-merchant can manage. Make sure they are properly routed ( as per originals ) and take care to check that there is no brake fluid leaking form the joints at caliper or master cylinder end.
Borrow a torque wrench if you can to tighten up the banjo bolts... and be careful not to over-tighten them. I had the thread strip on one once, and I ended up trawling breakers for a replacement caliper Rolling Eyes
Aside from that, bleed them afterwards, keep the brake fluid well away from any paintwork, and you can't go far wrong.
irving
PostPosted: 19:55 - 20 Oct 2006    Post subject: Reply with quote
Arrow
PostPosted: 19:58 - 20 Oct 2006    Post subject: Reply with quote
As above.
However make certain you do not buy braided hoses with alloy fittings.
dgk13
PostPosted: 10:52 - 21 Oct 2006    Post subject: Reply with quote
Thanks for your help guys, i'm going to get a quote at my local bike shop to see what the damage could be, how long roughly would it take to do this? Change two single lines? so i know they aren't fobbing me off.
Honda powwwwerrrr
The last post was made 19 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 48.18 Kb
