| virus |
 virus World Chat Champion
 Posted: 10:35 - 21 Oct 2006 Post subject: Clutch not working? FIXED Got a few other problems though |
OK, the clutch worked fine, needed some ajustment as the biting point was on the edge of my grip but thats solved.
which chains from busters (out of the 125cc 420 i think it is variety) have split links?
were can i get a centre stand for an '85 cg on the cheap? discovered today that mines been broken and welded back in the wrong place, thats why its a git to use.
how hard is it to remove 2 links from my chain to get the ajustment right, its already loose and its at full adjustment so my CBT instructor suggested taking 2 links out. ____________________ own: 81 xs1100g...
| G |
 G The Voice of Reason
| virus |
 Posted: 11:11 - 21 Oct 2006 Post subject: |
cheers G, ill give that a go later  ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| loply |
 loply World Chat Champion
 Posted: 11:17 - 21 Oct 2006 Post subject: |
The rear wheel usually rotates slowly when you let the clutch out in gear. Perhaps adjusting the clutch lever to seperate the plates a bit more will stop it.
In any case if you sit on the bike and the forward drive isnt strong enough to actually "pull" forwards then I wouldn't worry about it - I'd dismiss it as normal. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| hmmmnz |
 hmmmnz Super Spammer
| extreme3d |
 extreme3d World Chat Champion
 Posted: 16:40 - 21 Oct 2006 Post subject: |
You don't want to be lubing the chain with the engine on and the wheel turning in the first place. That chain will not stop for something like a finger. Remember a chainsaw is only 25cc yet try stopping that with your hand.... your chain is attached to 125cc
I can't remember the link off hand but there is a site somewhere showing in detail what can happen to a hand if you get it caught in the chain/sprockets. Does anyone have it?
ALWAY turn the wheel by hand with the engine off, it may take longer but it's a good deal safer.  |
| virus |
 Posted: 16:58 - 21 Oct 2006 Post subject: |
Yeah i get a better coverage of chain lube if i turn it by hand i was just reving it to get any exess chain lube off. anyway i went outside earlier and the clutch is working fine when the wheels are on the ground. cheers for all the help.  ____________________ own: 81 xs1100g...
| TheShaggyDA |
 TheShaggyDA Repost Police
 Posted: 17:08 - 21 Oct 2006 Post subject: |
| extreme3d wrote: | You don't want to be lubing the chain with the engine on and the wheel turning in the first place. That chain will not stop for something like a finger. |
If you have a tube in the end of the spray nozzle, your hand shouldn't be anywhere near the chain anyway. If you do the job with a modicum of respect for the machinery, you won't have a problem.*
* edit. If you are an anal retentive safety nazi, then don't do this, no siree. ____________________ Current: CB500 Previous: CB100N, CB250RS, XJ900F, GT550, GPZ750R/1000RX, AJS M16, R100RT, Enfield Bullet
| loply |
| virus |
 Posted: 21:50 - 22 Oct 2006 Post subject: |
clutch is working fine now the biting point has been adjusted
anyone got any ideas on my other problems though?
cheers
John ____________________ own: 81 xs1100g...
| G |
| virus |
 Posted: 22:11 - 22 Oct 2006 Post subject: |
Yeah as soon as I can afford it im getting a new chain and sprocket set for it, priority is the anoyyingly temramental light switchgear at the moment. Id rather have a centrestand than not, its working and it is quite useful, I prefer it over the sidestand as it holds the bike more secure, I feel more comfortable lying underneath it to change the oil with it on the centrestand.
of to ebay i go  ____________________ own: 81 xs1100g...
The last post was made 19 years, 328 days ago. Instead of replying here, would creating a new thread be more useful? |
