Chain Adjuster
Graham88
PostPosted: 00:05 - 22 Oct 2006    Post subject: Chain Adjuster Reply with quote
My chain adjuster has stopped turning on my VFR400R NC30.
It won't turn either way. I poured some degreaser on it to see if it was just clogged with dirt, but it still won't turn. I have a new C&S ready to go on as current chain is on maximum adjustment.
What's the problem?
And yes I have undone the bolt on the swingarm, before anybody asks. Smile
hmmmnz
PostPosted: 01:27 - 22 Oct 2006    Post subject: Reply with quote
a bit of wd40 or some heat might be on the cards, failing that, chop the bolt and drill it out,
or undo the rear sprocket and pull the whole thing off.
(im not familar with how the adjustments work on a single sided swing arm, i only had the vf400 and that was a normal swing arm, sorry)
good luck
the humans are dead
I kick arse for the lord
kat250
PostPosted: 01:40 - 22 Oct 2006    Post subject: Reply with quote
I believe they work on a concentrack*sp cam. Probably stuck due to corrosion maybe worth pulling all the bits off and giving the hub a good clean up and a good grease up.
in the famous word of jimmy pop "would you F*ck me for blow"
In the words of banditshigh "would you blow me to f*ck"
Graham88
PostPosted: 20:25 - 22 Oct 2006    Post subject: Reply with quote
Can anybody give me an in depth account of removing the bits from the swingarm?
Starting from removing the plate that holds the chain and sprockets on if possible.
And becoming this:
https://www.pgoffline.com/vfr750r/resized/dcp_0194.jpg
Cheers.
V2
PostPosted: 01:44 - 23 Oct 2006    Post subject: Reply with quote
i believe this may help
https://www.400greybike.co.uk/Forum/topic.asp?TOPIC_ID=43633
you may need to register to see it though..
Graham88
PostPosted: 02:04 - 23 Oct 2006    Post subject: Reply with quote
Cheers mate, explains a little bit better, but kind of skips the bit I'm confused with. Never mind, will have a go myself tomorrow.
The last post was made 19 years, 326 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 15 - Page Size: 46.66 Kb
