33bhp Blade Restrictor
xp-power
PostPosted: 15:50 - 23 Oct 2006    Post subject: 33bhp Blade Restrictor Reply with quote
Ive want to remove my 33bhp on my rvf 400, looked on the certicate and it says its a Blade Restrictor, Any one help please
Sorry about all the stupid questions but my rvf is the love of life and i dont want to fuck it up and i dont wanna pay £35ph work on getting it removed
Thanks
xp-power
code guru
PostPosted: 17:47 - 23 Oct 2006    Post subject: Reply with quote
hi mate, take your tank off, then your air box, then your carbs and the blades r in the tubes that connect to the engine from your carbs. they r like washers. just pull them out. theres one in each tube so theres 4.
xp-power
PostPosted: 18:11 - 23 Oct 2006    Post subject: Reply with quote
So how hard are the carbs to take off then becuase i have heard they are right bi*ches
code guru
PostPosted: 18:57 - 23 Oct 2006    Post subject: Reply with quote
well it shouldnt be that hard. your bike is a v4 i think
but at the end of the carb just undo the clip with a screw driver.
extreme3d
PostPosted: 19:00 - 23 Oct 2006    Post subject: Reply with quote
Usually not that hard. There will be a jubilee clip (belt type clip with a screw) at each end of the rubber carb/engine joining hoses. You need to loosen these and pull the hose off. Getting them back on can be hard but try without any form of lube at first. They should pop back on. If not use a thin smeer of light oil.
The last post was made 19 years, 324 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 43.04 Kb
