Nitrous GSXR
TL666
PostPosted: 15:47 - 23 Oct 2006    Post subject: Nitrous GSXR Reply with quote
I'm about to install nitrous to my old GSXR oilboiler engine. Would it be better to postion the injectors on the carb inlet rubbers or should I drill the carb inlets themselves? I've read quite a bit about installing nitrous but haven't found much info on this.
(The engines an '89 shortstroke 750 and the carbs are 38mm mikuni flatslides)
gixxersixx
PostPosted: 16:29 - 23 Oct 2006    Post subject: Reply with quote
https://www.aperaceparts.com/nos.html
these guys know what they are talking about when it comes to nitrous kits they also do a kit that fits between the carb rubbers and the cylinder head hope this helps Smile
We're all just born to die. So lets have some fun
gsxr6k1,pc,k&n,skimmed block,flowed head,yoshi gasket,cams,blue print,arrow system titanium can,quick shifter,gilles rear sets,ktech forks,ohlins shock,galfer waveys, -3front+4rear + other goodies
TL666
PostPosted: 17:12 - 23 Oct 2006    Post subject: Reply with quote
I've already got the kit. Just wondering if the postition of the fogger nozzles would make much difference
0ddball
PostPosted: 17:58 - 23 Oct 2006    Post subject: Reply with quote
In general the closer to the inlet valve the better. It gives the nitrous charge less time and distance to absorb heat.
The system will be a little less efficient (less bhp/min/lb nitrous) if you mount further from the inlet valve but unless you are drag racing and looking for every little extra % it's not significantly important.
Depending on how pooly designed the injectors (nitrous) are it is sometimes better to install them in the bottom of the intake runners where they cause less restriction to flow.
What make of kit did you get btw?
TL666
PostPosted: 18:05 - 23 Oct 2006    Post subject: Reply with quote
Thanks for that Spanner monkey. Its a Dynotune kit. I only want an extra 40bhp so i'm not too bothered just like doing things correctly.
PostPosted: 19:59 - 23 Oct 2006    Post subject: Reply with quote
How is it activated?
The thing with nitrous is that if you put a 40-shot into it, you get 40HP increase, instantly, regardless of revs or throttle openings. You want to be on at least 80% throttle, prefereably higher before the nitrous activates. You also need to be at fairly high rpm. Too low a rpm and your cylinder pressures will go through the roof and the results can be devastating for your engine.
TL666
PostPosted: 06:55 - 24 Oct 2006    Post subject: Reply with quote
Its activated on full throttle. I'm aware of how nitrous works.
sub4sec
PostPosted: 08:56 - 24 Oct 2006    Post subject: Reply with quote
Post a vid when you`re done Cool
New videos every week > www.sub4secvideos.nl
Track-instructor / Marshall
https://www.youtube.com/watch?v=PRT_5h1-7ns
TL666
PostPosted: 13:46 - 24 Oct 2006    Post subject: Reply with quote
I will if I can work out how to do it. Hopefully it won't be one of me blowing up my engine Smile
GodzGift
PostPosted: 15:05 - 24 Oct 2006    Post subject: Reply with quote
ahhh yeah man i wanna see this, good luck with the installation,
be safe Thumbs Up
Bike Level: Amateur | CBT Passed
TL666
PostPosted: 18:06 - 24 Oct 2006    Post subject: Reply with quote
I think i'm going to have to take some photos of the installation and a video of the end result Cool
PostPosted: 18:15 - 24 Oct 2006    Post subject: Reply with quote
Glad to hear it. So many people throw nitrous systems on their bikes without doing any research end up in a world of expensive pain.
The last post was made 19 years, 325 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 72.76 Kb
