Looking for a replacement brake lever
PostPosted: 21:00 - 23 Oct 2006    Post subject: Looking for a replacement brake lever Reply with quote
To fit to this Jawa I'm doing up. The bars are bent and fitting new bars means that they won't have the welded on brackets that take the original levers. I'm going to use a set of my spare KLE handlebars and I have a clutch lever assembly off my spare GPZ.
What I need is a front brake lever assembly that will clamp onto a standard size handlebar. But here's the problem:
Arrow It is CABLE operated.
The bike weighs in at 350lb and has a twin leading drum so said lever needs to be:
Arrow Strong.
Arrow Fairly long.
Arrow Have a longish travel.
As such a lever off a 125 probably wont be up to the job.
Ideally it would also have:
Arrow A built in brakelight switch.
Which rules out a 'universal' motocross one.
If I know which model of bike to look for, I can probably find one in a breakers or on fleabay.
Suggestions welcome. We're probably looking at 1970's jap bikes here but anything a bit more modern would be great (span adjusters and suchlike are nice when you have them).
finpos
PostPosted: 21:14 - 23 Oct 2006    Post subject: Reply with quote
As a thought, how about using a modern clutch lever and either mounting it upside down or trying to otherwise jigger it left-to-right (which you'd need to do with the span adjuster)? Don't really know how successful that would be, mind.
finpos.
PostPosted: 21:23 - 23 Oct 2006    Post subject: Reply with quote
finpos.
Never really thought of that. Good idea. I'll have a fiddle with my spare GPZ one. They have an idiot switch on them too which would double as a brakelight switch. Thinking
The last post was made 19 years, 324 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 36.56 Kb
