| Rookie |
 Rookie World Chat Champion
| G |
 G The Voice of Reason
 Posted: 12:47 - 24 Oct 2006 Post subject: |
Filtering.
The following on motorway style filtering:
First, erm, remember it’s not supposed to be a way to enjoy yourself – it’s a system to help you get from A to B quicker (yes, I’m a hypocrite).
Don’t filter above the level you’re happy with. If you find you’re holding people behind you up, do pull in and let them past when it’s safe for you to do so. If someone you're riding with goes faster than you; let them. They should slow before the next junction you have to turn off at; if they're the sort that doesn't, either find someone that does to ride with or make sure you know your own way!
When you can, make clear moves and decisive moves.
For instance, if I’m moving from the outside lane to the middle lane to make use of an empty gap, I will often flick the indicators on; despite the fact I have made sure it is safe to move regardless of other vehicles, this may give other vehicles ahead more of an idea of where you are and are intending to be.
Put yourself as far away from danger as possible.
Danger generally refers to other larger vehicles in this case. So, if you’re weaving due to alternately placed cars, try and exaggerate it a bit, so that you spend more time further away from the vehicle you're next to. This way if a vehicle starts to move into your lane, you’ve got a bit of time to take avoiding action. This also means that while you’re at the back of the vehicle, you’re moving away from them and it’s only when you’re at the front of a vehicle, with a higher chance of being seen, that you’re moving back towards them.
When driving in a lane at a higher speed than a lane next to you; consider your positioning. If you’re on the outside or the inside, it’s usually worth moving a bit further over, away from other vehicles. Though do consider things like vehicles on the hard shoulder - are they likely to pull out into your lane?
With vehicles on either side, which is likely to present the most danger? Generally, the middle of the lane is best in these cases however.
I often prefer to filter between two vehicles than alternately placed vehicles. Generally cars seem to have a better awareness of the car next to them, so are usually less likely to pull into that space through you. Don't presume that's always the case though; in my barge of a £115 Passat estate I still had people not seeing me when I was right next to them!
If you really need to get out of the way of a vehicle, remember you can lean your bike! Obviously this only gives you a little bit of grace until you have to work out where you want your now turning bike to end up. A lot of the time though a second is all that's needed to pass the car that your shoulder or arm might have clipped if you hadn't been leant over. Do remember that as you start to lean your wheels are still in the same place; however it's usually higher up parts of the vehicle that are the problem.
Of course, the idea is to avoid situations like this.
If you need to brake harshly, remember your conditions' cat's eyes and white paint are not ideal braking surfaces, so try and ensure you tyres aren't on these at the time.
Know what's going to happen, before it happens.
One of the things I do seem to enjoy is the almost zen-like state you can achieve where the mind is totally focused on the surroundings. Good peripheral vision is important, but generally not as much as looking ahead.
If something starts to move into your lane while you're next to it and doing a decent speed, you'll have probably passed by the time it poses a danger.
Looking down a line there's lots of general things to consider. For instance, how wide is the space between the traffic? In slow traffic; Is there spaces on either side of your path that cars may decide to pull into? Are there cars ahead that are closer together across your path (even anyone obviously talking to their mates across the lanes)?
Is there a junction ahead, cars changing lanes or moving to one side of a lane, a wide or erratic looking vehicle ahead? This sort of thing can suggest that there's more likely to be people randomly changing lanes.
These and more can be used to set your speed and to plan ahead where you need to take more care.
For instance, trucks often may pull out quite suddenly after slipstreaming another truck; this could result in, say, the van just behind in the middle lane suddenly flicking over to the outside lane to avoid losing momentum.
Closer to vehicles, there's some tell tale signs that someone's about to move. A flashing indicator is the obvious one, but the car's angle to you changing slightly, or wheels starting to turn are slightly more subtle ones.
Note that just because an indicator's on, doesn't mean anyone's at home (groan, sorry). It maybe they've left it on, or are waiting for you to pass before they move though the latter is unlikely. Similarly, someone may be swerving about in their lane while digging around in their pocket for a mobile, but not actually move into your path.
If I do see someone moving, I will usually try and stop in plenty of time; giving them a flash and a wave if they have seen me and pulled back into their lane; suggesting that at least I knew what was going on and was riding safely, even if they didn't!
Pulling out to start filtering? Definitely make sure you've had a good look behind to make sure there's not another bike coming at high speed between the vehicles. Similar if you're swapping
When exiting from two larger vehicles, act on the knowledge you have; so if you can't see what's happening in a lane due to a truck cabin blocking in your view, don't move into that lane, however clear it looks further ahead, until you can be sure there isn't another car trying to be in the same bit of road from the other lane.
While I list lots of things to think about, that Zen-like state I like usually has a lot less conscious thought; and getting to this point is going take experience rather than listening to other people on the net.
Filtering in towns is another skill set again.
For instance, I think it's a bit ridiculous to say "don't filter past junctions" - in some places this means don't filter at all, especially when there's a line of people's houses down the road. However, they should be taken into account as another hazard to consider and a particularly serious one.
Think I've waffled on enough however, so I'll leave it at that.
I, of course, wouldn't filter in any way I'd consider to be adding danger. However I asked someone at work and this is what they said:
To start with, it depends massively on the conditions, there is no hard and fast rule; you just have to go with what you're comfortable with. Trying to follow 'guidelines' is going to cause you more problems than it solves; you can't just say 'oh the traffic's doing 'Xmph', so I'll do 'X+20mph' - in a similar manner, you can't drive at the speed limit all the time and be safe; sometimes it's only safe doing under it, sometimes you can be safe doing double it.
Stationary traffic: Up to about 60 in the best conditions if I'm in a serious hurry, but more realistically a maximum of 50 in good conditions if I'm in a bit of a hurry with tightly packed (front to back) traffic unlikely to move and decent space between lanes.
20-30: Maybe a maximum of 70-80mph or so. At moderate low speeds people have more chance to change lanes etc.
70-90: Up to about 130/140mph; depends on the situation as ever.
Wet: Depends massively on the conditions; very light drizzle; maybe similar to the above. Moderate to heavy rain, probably 100-110mph or so. |
| edd |
 edd Nearly there...
 Posted: 13:13 - 24 Oct 2006 Post subject: |
1) What speed do you filter at through stationary motorway traffic?
15-25mph maybe up to 30 ish if theres a big gap.
2) What speed do you filter at through slow moving traffic (10-30mph)? usually I pass the slow moving traffic at about 40, because they are sometimes stopped and sometimes doign up to 30.
3) What speed, if any, do you filter at through normal moving motorway traffic(70-90mph)? Very rarely do this, chance of death is quite high
4) Do you reduce your speed when it's raining, if so by how much, or do you stop filtering altogther? I reduce my speed generally but dont stop filtering. ____________________ Bluespark Automotive - Diesel Tuning for Performance and Economy |
| Itchy |
 Itchy Super Spammer
 Posted: 13:18 - 24 Oct 2006 Post subject: |
if you want a lesson lie in wait in Central london and follow a courier for a bit , a middle distance courier who isn't on a 125 (which implies that he is a short distance courier IMO) , a Bros/NTV ought to be a good clue.
if you are hardcore look for pans and other bigger bikes with fairings on them, and follow them , you might end up in Scotland.
if you want a Manchester lesson look for a guy in a ROOF green helmet on a naked street fighter'd Yam IL4 which is yellow has a Isle of man plate ,this is TT man , who is a crazy filtering bastard , who will end up dead banned or both sooner or later , since he mounts pavements and stuff.
EDIT
As said Sickpup this is a fantastic opportunity to open a school , for fast filtering £50/h teaching n00bs how to filter must be better than the 65p/mile you get no?. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| T1z3R |
 T1z3R World Chat Champion
| G |
| Itchy |
 Itchy Super Spammer
| alone |
 alone Traffic Copper
| G |
 Posted: 13:35 - 24 Oct 2006 Post subject: |
I have wondered about sticking my bullet cam and HDD corder onto the front of me bike at some point. Though I so know that will be the day I have a crash and the police turn up before I can do 'owt about it .
It has been done before, but not as exciting footage as it might seem "on it's own". |
| st3v3 |
 st3v3 Super Spammer
| Irezumi aka Reuben |
 Irezumi aka Reuben Carrot Top
 Posted: 22:14 - 24 Oct 2006 Post subject: |
Thanks for all the reply's, have found them very helpful.
I was just asking a few question's as i already filter every day so have a fair idea of what I'm doing, just looking to improve my safety. A20->M25->M23->A264 mean's that I can filter, or sit getting wet, in which case I should just buy a car.
Just going to pick up on a couple of point's.
| Quote: | So, if you’re weaving due to alternately placed cars, try and exaggerate it a bit, so that you spend more time further away from the vehicle you're next to. |
I tend to sit in a constant line, avoiding the white lines/cats-eyes as i feel this allows me to better apply the brake/turn if necessary. If I'm already moving in one direction it requires more force to then turn the bike or stop it, and more importantly more time. Although I do see where your method has an advantage.
| Quote: | You live in London rules are different |
I've found that at low to medium speed that filtering is pretty similar, some slow, some fast. It's only once you get to higher speed stuff, 70mph+ where people further south still filter and those from the midalnd's upwards don't.. |
| alone |
| sickpup |
 sickpup Old Timer
| gavin |
 gavin World Chat Champion
 Posted: 00:39 - 25 Oct 2006 Post subject: |
london couriers are fast? nah, they just think they are
amazing how pissy some of them get when you out filter them too......
a bit like some black cabs, thinking they are the best 4 wheel gap pickers. they dont like it up 'em either i spent ten years as a rep driving in london, upset a few.  |
| G |
| Arfdog |
 Arfdog Crazy Courier
| TheShaggyDA |
 TheShaggyDA Repost Police
| G |
| Psychonaut |
 Psychonaut Spanner Monkey
| 0ni |
 0ni World Chat Champion
| Finglonga |
 Finglonga World Chat Champion
| 0ni |
| THCi |
 THCi Nearly there...
| Itchy |
 Itchy Super Spammer
The last post was made 20 years, 26 days ago. Instead of replying here, would creating a new thread be more useful? |
