Checking oil level on NC24
birdy
PostPosted: 13:24 - 25 Oct 2006    Post subject: Checking oil level on NC24 Reply with quote
Friend of mine just got & repaired a NC24 (got it for around 4000ZAR, which is equal to about 330pounds) and spent another 200pounds to get it in perfect condition. 6000km on the clock.
Problem is that he didn't get a manual with the bike and I do not have the experience with smaller bikes that is needed to help. Have gotten hold of the NC30 workshop manual which seems to cover most of what is needed, but cannot find any mention on how to check the oil level - on the sidestand or whilst bike is held upright. Question
Is the procedure the same as with the CBR1100XX - start the bike up and let it idle for a couple of minutes, then switch off and let oil drain to bottom for a couple of minutes then check on dipstick.... Question
Then as well: according the the NC30 manual, 2.5l oil is needed on oil & filter change. Is this correct.
Thanx
birdy
birdy
2005 Honda Blackbird (two-tone blue)
V2
PostPosted: 14:22 - 25 Oct 2006    Post subject: Reply with quote
Bike upright then there is a little dipstick joined to the oil filler cap, i dunno about letting the bike run, i never did and if i remember correctly its 3.5 litres for an oil change with filter
PostPosted: 15:27 - 25 Oct 2006    Post subject: Reply with quote
Don't need to run the bike. Just check it with the motor cold. The bike MUST be on a level surface and upright though. So not on the sidestand/paddock stand.
The amount of oil to put in should be on the R/H engine casing somewhere.
sickpup
Old Timer
PostPosted: 17:45 - 25 Oct 2006    Post subject: Reply with quote
I'll check on mine when its stopped pissing down but pretty sure this is wrong and they have a seperate level dipstick under the oil filler cap lower on the crank case cover.
V2
PostPosted: 20:57 - 25 Oct 2006    Post subject: Reply with quote
ah now you say it yes i think they are separate, apologies! i didnt go out and check cos its pissing down here too!
The last post was made 19 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 43.75 Kb
