Basic requirements for mot...
jimbothe
PostPosted: 14:57 - 25 Oct 2006    Post subject: Basic requirements for mot... Reply with quote
Can anyone please tell me the basic bits i need on the front end for a mot.
My zx has been giving me loads of troubles converting it to a streetfighter and now i think the only way is to minimise so i can get it through it's ticket.Once through i may retry a few ideas but i needed it back on the road yesterday Sad
Obviously i have the lights/indicators on,the bits im concerned about are the tacho as in there isnt one and warning lights.
On most of the tachos or separate units the lights are there for neutral/oil/high beam.
I can make up something to house these with simple coloured led's if needed but wondered if it would go through a test without them and the tacho?
Any advice much appreciated Thumbs Up
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
jimbothe
PostPosted: 15:28 - 25 Oct 2006    Post subject: Reply with quote
cool,cheers for that.So i just need to get a 'winker' to show the left and right indication and a high beam light.Does it have to be blue?
R1stu
Shrek!
PostPosted: 13:01 - 26 Oct 2006    Post subject: Reply with quote
just remove the indicators all together. They cant test whats not there!
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
gixxersixx
PostPosted: 13:23 - 26 Oct 2006    Post subject: Reply with quote
Thats true and depends on what tester you get and the mood he's in.
But for the mot if your bikes got lights it has to have a full set
We're all just born to die. So lets have some fun
gsxr6k1,pc,k&n,skimmed block,flowed head,yoshi gasket,cams,blue print,arrow system titanium can,quick shifter,gilles rear sets,ktech forks,ohlins shock,galfer waveys, -3front+4rear + other goodies
R1stu
Shrek!
PostPosted: 13:25 - 26 Oct 2006    Post subject: Reply with quote
Not a legal requirement to have indcators on a bike! however, if they are there they must all work correctly along with the instruments!
gixxersixx
PostPosted: 13:39 - 26 Oct 2006    Post subject: Reply with quote
R1 Stu wrote:
- Not a legal requirement to have indcators on a bike! however, if they are there they must all work correctly along with the instruments
For the mot if the bike was registered after august 1986 then indicators are required. If you have lights on the bike then you have to have a full set for the mot.
Itchy
PostPosted: 14:05 - 26 Oct 2006    Post subject: Reply with quote
take the piss and remove your entire engine!,
other points of note:
suspension (fork seals) leaky rear shock
more than 1.5mm on unsquared tyres
bars that are not too bendy like mine
working lights
brakes that work on the brake test machine
pads with visible amount of material (its supposed to be about 2mm but they generally can't be fucked to take out the pads and measure it).
oh wait I didn't read it right:
for £5 you can make any light work on your bike , not fixing it just wire up some wires to the battery and stick in some switches here and there, mine just have loose conncetions
but I;'ve seen dodgy wiring to make it work ie connect a wire from the bulb in series all the way up to the instrument panel, for both bulbs hey presto it works again.
jimbothe
PostPosted: 18:42 - 26 Oct 2006    Post subject: Reply with quote
Cheers for all the replies everyone,mine is newer than 86 so i guess it needs indicators.They are on there anyway so it's not a problem.I will have to get a winker sorted out though to show the indicators working.I have bought a blue light today for the high beam so it's slowly coming together Smile
The last post was made 19 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 2.12 - MySQL Queries: 13 - Page Size: 69.39 Kb
