1990 NS 125 de-restriction
st3v3
PostPosted: 20:22 - 27 Oct 2006    Post subject: 1990 NS 125 de-restriction Reply with quote
i am looking at the methods of de-restriction for a honda ns125f, it is just going through MOT, and how easy are fork seals to replace, i have a sneeky feeling they might be picked up on but what are the pro's/cons of de-restriction, and is it worth it, how easy to wheely these? Cool
PostPosted: 20:34 - 27 Oct 2006    Post subject: Reply with quote
The NS was restricted in the exhaust and by leaving off the power valve. Nothing you can do about the power valve really (it isn't that effective anyway, just being a chamber on the side of the exhaust port, closed off on full power engines at high revs).
Stock exhaust with the restrictions taken out was pretty effective. Cheaper just to find a Micron or the like though.
The airbox was pretty restrictive on the NS125.
Have you got a manual for the bike?
st3v3
PostPosted: 21:00 - 27 Oct 2006    Post subject: Reply with quote
actually i'm starting looking for a manual, plus it came with a micron on it,it is NICE, but takes a while to warm up on these type of mornings...of course, once it's warmed up, the throttle is not shy! Cool
RS1Banger
PostPosted: 23:07 - 28 Oct 2006    Post subject: Reply with quote
if you block up the hole where the powervalve is supposed to be that makes them derestricted
i blocked the hole up on a mates mtx125 (same engine?) with jb weld, and it made it a different bike, very flat low down but pulled nicely from 6 to 10 grand,
we changed the jet and front sprocket too
if you take the exhaust off, you can feel the hole just inside the exhaust port, clean it up and fill it in, dont use exhaust putty it falls out, and be careful you dont get crud in your cylinder
The last post was made 20 years, 27 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 40.66 Kb
