Aprilla mx 50
2006 _p1
PostPosted: 13:56 - 28 Oct 2006    Post subject: Aprilla mx 50 Reply with quote
i know this question has been asked loads of times but i have just brought one of these the 04. it does 40 50 down a slope.does any one know where the restriction is in these. i have a rough idea but not entireley sure. many thanks nathan
PostPosted: 15:21 - 28 Oct 2006    Post subject: Reply with quote
Think it is mainly in the exhaust, although people have mentioned that the later ones have restrictive exhaust ports (think).
Would expect around 50 indicated on the flat if fully derestricted.
2006 _p1
PostPosted: 19:15 - 28 Oct 2006    Post subject: Reply with quote
so do you think mine will be in the ports? mine is 2004!
PostPosted: 20:15 - 28 Oct 2006    Post subject: Reply with quote
Honestly don't know enough about the 50 to comment, but might well do. Think the barrels are cast iron so not quick to play with.
Finglonga
PostPosted: 11:34 - 29 Oct 2006    Post subject: Re: Aprilla mx 50 Reply with quote
Down a slope doesn't coun't a fully restricted bike will reach 50 if you throw it off a cliff. Mr. Green What does it do on the flat? As Keith said above if it does 50 it will already be de-restricted.
Andy Sez....
F.Y.Y.F.F.
RS1Banger
PostPosted: 20:22 - 29 Oct 2006    Post subject: Reply with quote
the 2004 am6 engine (in your mx50) does have a smaller exhaust port, but its not a restriction
also the carb is only 12mm which again isn't a restriction, its just a bit small
the restriction is in the exhaust
you need to find the obstruction and remove it
it may well be easier to fit a new exhaust like a gianelli or yasuni (best)
some of these come with an adapter to enable them to fit exhaust ports on earlier and older models
nearly all cylinder kits have the larger exhaust port like the older engines
if you fit a larger carb you need to remove a restrictor from the reed valve stub, this isnt really a restrictor unless you fit a bigger carb, so leave it in if your carb is standard
2006 _p1
PostPosted: 21:40 - 29 Oct 2006    Post subject: Reply with quote
ok cheers guys it does around 40 on flat
2006 _p1
PostPosted: 22:55 - 30 Oct 2006    Post subject: Reply with quote
does any one no where i can get a race exhaust? thanks nathan
2006 _p1
PostPosted: 11:55 - 31 Oct 2006    Post subject: Reply with quote
any one? Question Smile
RS1Banger
PostPosted: 23:42 - 31 Oct 2006    Post subject: Reply with quote
do a search on the web
germany and holland are far cheaper than the uk, even after postage
www.50cc.nl will give you an idea, but i think they're not the cheapest
Welshd1k
PostPosted: 15:23 - 04 Nov 2006    Post subject: Reply with quote
fisr is first has it got a digi dash as some 2004's where the last of the old version
if it is non digi ony rwstrictions are the 12 tooth front sprocket and the exhuast! my old one had a cheap shit end can bodged to fit and a 13 tooth front would cruise at 50-55 got video on my fone of my mate on it doing a constatnt 50 easy
if it is the digi dash get a arrow system for it and a 13 tooth sprocket also there is a pipe on the carb that needs to be blanked of (not sure if all of them have them) or simpler see the pipe on the expansion chamber cut it and clamp it shut and you will be a bit better and blow torch the mufflers out of the end can and it will go better
The last post was made 19 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 66.57 Kb
