| kkhalil76 |
 kkhalil76 Nova Slayer
| hazza |
 hazza World Chat Champion
| kkhalil76 |
| hazza |
| kkhalil76 |
| XR125 |
 XR125 Renault 5 Driver
| kkhalil76 |
| XR125 |
| kkhalil76 |
| Marci |
 Marci Brolly Dolly
 Posted: 18:17 - 30 Oct 2006 Post subject: |
Hmmm.... bad choke practice mefinx. Choke shouldn't be on whilst riding. If you need to keep choke on then generally it means you're running lean.
You should use choke only to get bike to start, then knock it off before riding. Most bikes stall if choke is left on and you don't have throttle open to keep it rev'd... that's cos at the point in time when that happens, the choke shouldn't be on.... basically.
I open choke to full, fire up bike, keep choke held open until revs start to drop by themselves, then immediately close it and let the bike idle to warm up... All this done without touching the throttle at all. It remains closed for the entire startup procedure. ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk |
| kkhalil76 |
| XR125 |
| kkhalil76 |
| lanester |
 lanester Borekit Bruiser
 ---- World Chat Champion
| eddclarke |
 eddclarke Brolly Dolly
| eddclarke |
 Posted: 01:37 - 31 Oct 2006 Post subject: |
thanks... |
| kkhalil76 |
| eddclarke |
| finpos |
 finpos World Chat Champion
 Posted: 12:00 - 31 Oct 2006 Post subject: |
Oooh. It's a trial bike with a CG125 Engine.
The choke behaviour is typical CG125. If you start on full choke, it won't keep running like that. You immediately have to put it onto half-choke. After less than a minute it should be warm enough to run on no choke at all, but, obviously, it depends on how warm/damp the weather is.
With the kind of choke it is, you'll probably find the only difference riding it with the choke on is that you loose top end speed. For the geeks amongst you, it's a genuine choke, not the normal enrichment circuit that everybody else has and that they call a choke.
Nobody seems to have mentioned it here, but I take it you have kept the chain adjusted properly? What you have does, indeed, sound like lash, but it could be either poor adjustmnet or just that it's inherent to the bike design (presumably, it's got long suspension at the back so the chain needs to be a bit slacker than normal)
finpos. |
| kkhalil76 |
| finpos |
 Posted: 12:18 - 31 Oct 2006 Post subject: |
"heavy duty" (standard fitting for that type of bike) chain + a couple of months without oil (rusty?) = dragging on floor. Get it adjusted. And lubricated.
finpos. |
| kkhalil76 |
The last post was made 19 years, 359 days ago. Instead of replying here, would creating a new thread be more useful? |
