Only three cylinders working.
Sephiroth
PostPosted: 23:05 - 31 Oct 2006    Post subject: Only three cylinders working. Reply with quote
Suzuki Bandit 400, 1992 import blah blah blah.
Well today the bike is only running on three cylinders.
The second cylinder's HT lead was being pulled quite a bit as the lead was very short. I moved it a bit while the bike was running and it fired up on all four randomly.
Checked and there is a spark.
Any ideas?
Might of dropped a valve which I very dearly hope not.
irving
PostPosted: 23:12 - 31 Oct 2006    Post subject: Reply with quote
Arrow
mchaggis
PostPosted: 23:13 - 31 Oct 2006    Post subject: Reply with quote
It's possible the HT lead doesn't sit properly on the spark plug when it's in the engine but will do fine when the plug is out of the block. Either get it to sit properly onto the plug, or get an HT lead which is long enough to and try again.
I'm a bit perplexed as to why an HT lead should be too short unless somehow it has managed to be routed incorrectly? Eh?
Be careful with HT circuits when they're running. They can give you a hell of a jolt (my thumb felt like someone hit it with a hammer) and potentially get you into trouble.
I must not be a troll...
Mmmm, Guinness
Sephiroth
PostPosted: 23:23 - 31 Oct 2006    Post subject: Reply with quote
Sorry, the length of the lead was okish before i had a problem, but it was 'just enough' so to speak.
The bike was running on three cylinders before I had a look.
I've changed the lead for a longer piece and still no joy (but at least it's long enough now).
I was in work on my lunch break when I took a look at it first off. As I had no tools I couldn't take the tank off to check everything. I noticed the lead was a bit tight and pulled it a bit so it fit into the coil a bit more and then it proceeded to run on four cylinders.
Then I let go of it and then it went back to three.
irving
PostPosted: 23:28 - 31 Oct 2006    Post subject: Reply with quote
Arrow
Walloper
PostPosted: 12:39 - 01 Nov 2006    Post subject: Reply with quote
That's funny mines only runs on three two.... Laughing
Sephiroth
PostPosted: 19:22 - 01 Nov 2006    Post subject: Reply with quote
Problem solved.
Even though I could see a spark, the plug was a bit fooked.
Rushed down to Busters and bought a new one, popped it in outside the shop and rode home.
I know it's only a little 400, but I forgot how fast it actually was.
Thanks all anyway.
The last post was made 19 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 55.98 Kb
