Cg125 chain and sprocket replacing
virus
PostPosted: 00:04 - 01 Nov 2006    Post subject: Cg125 chain and sprocket replacing Reply with quote
ok so ive got a new chain and sprocket set for my bike but the haynes manual is confusing, also my back wheel is buckled so if i took the wheel off then i could get it fixed at the same time which would be a good idea i think.
Basicaly im looking for a guide to change the chain and sprockets on a '85 model if anyone could help.
Thanks
John
own: 81 xs1100g...
veeeffarr
PostPosted: 00:55 - 01 Nov 2006    Post subject: Reply with quote
Take Chain Guard off
Undo rear wheel bolt
Undo chain adjusters
Get a screwdriver and remove the split link from the old chain
Remove chain
Undo LEFT hand side engine cover and undo the nuts on the front sprocket, take it off and put the new one on
Remove rear wheel
Remove rear sprocket
Put new rear sprocket on
Reinstall rear wheel at forwardmost position
Put new chain on and do up split link
Replace engine cover (New gasket)
Replace rest of parts
virus
PostPosted: 10:38 - 01 Nov 2006    Post subject: Reply with quote
great cheers toby Thumbs Up
own: 81 xs1100g...
veeeffarr
PostPosted: 11:22 - 01 Nov 2006    Post subject: Reply with quote
Problem areas will be the rear axle bolt and the gasket on the engine case, it will probably rip when you take it off.
Bigeds
PostPosted: 17:17 - 01 Nov 2006    Post subject: Reply with quote
Needed to do this myself earlier in the year and found Toby R's thread from when he asked the question here very handy.
One or two pictures included from other members.
BTW Cheers Toby R Thumbs Up
(Feb06) Honda CG125 - (Jun06) Suzuki SV650S K1 - (Apr11) Moto Guzzi Griso 1100
virus
PostPosted: 18:39 - 01 Nov 2006    Post subject: Reply with quote
Brick Wall Doh! BUGGER!!
i took the chain case off, and the sprocket cover, and the chain, and the old front sprocket, then i overtightened the bolts that hold the front sprocket on and ripped the heads off!! Sad i need to get this done by sunday for my CBT.
Anyone know were i can get replacment bolts Question
own: 81 xs1100g...
veeeffarr
PostPosted: 20:28 - 01 Nov 2006    Post subject: Reply with quote
www.wemoto.com or www.davidsilverspares.co.uk
Paddy Blake
PostPosted: 21:16 - 01 Nov 2006    Post subject: Reply with quote
You should be able to get one in a hardware shop.It might be too long so
put it trough the plate and screw it into the sprocket then saw off the and.
virus
PostPosted: 20:30 - 02 Nov 2006    Post subject: Reply with quote
Got some new bolts Smile
Ive fitted the rear sprocket now i just dont know were the metal tube that came out of the drum goes, i took the wheel off and a little piece of metal pipe popped out of either side, ive done the sprocket side one but cant figure out for the life of me how to get the one from the drum back in Crying or Very sad
why is there no way of doing things with no problems?
p.s. I shot myself with a circlip Laughing when I was putting it back on it pinged of into my arm, thank god I had a coat on because it went pretty fast.
own: 81 xs1100g...
virus
PostPosted: 16:30 - 03 Nov 2006    Post subject: Reply with quote
problem solved, ive done it all now, cant wait till sunday and im taking a few tools along just incase i havent alligned the wheel properly. Smile
own: 81 xs1100g...
The last post was made 19 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 66.61 Kb
