| Timmeh |
 Timmeh World Chat Champion
| Kickstart |
 Kickstart The Oracle
 Posted: 21:54 - 01 Nov 2006 Post subject: |
Firstly check the main jet and needle jet. It does sound like it is running very rich, but this could be a very obvious carb problem (with a Gilera CX125 which uses the same carb we had the attomiser tube shear off from vibration, giving a hideously rich mixture and bending the needle jet).
Unfortunatly the owners handbook for the 4DL does not list the standard jetting.
| Timmeh |
| Kickstart |
| Timmeh |
 Posted: 00:11 - 02 Nov 2006 Post subject: |
woo ta!
Another question if I may.
Are there any symptoms that would indicate a rebuild is in order? Would I start to suffer from lack of performance or is it strictly a mileage thing? ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
| Kickstart |
| Timmeh |
 Posted: 00:49 - 02 Nov 2006 Post subject: |
cool.
As soon as I can afford it I'll get it done.
Thanks again  ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
| Timmeh |
 Posted: 02:27 - 28 Nov 2006 Post subject: |
OK, here's an update:
Had a really good look all round the bike, found several breather pipes blocked with dirt including the carb drain hoses and the one that goes into the bottom of the tank. Cleared the blockages, dismantled the carb, cleaned it out, got a colortune.
At idle the colour's a nice deep blue with the odd flash of yellow which I know is what I'm looking for. I've got instant off-idle response and more power down the bottom end, but the power band isn't as defined and I think I'm missing some top-end performance.
Would I be right in thinking that the needle jet is now too lean? At the moment the clip is one setting towards the top rather than in the middle, so would putting it back in the middle help?
The air screw is a full 2.5 turns out so should I put it back in a quarter of a turn to make it slightly more rich?
Thanks for all your help btw, I'd be a bit lost without some sterling advice I've found on here.
The last post was made 19 years, 224 days ago. Instead of replying here, would creating a new thread be more useful? |
