NSR Front Wheel Q
moonym20
PostPosted: 22:01 - 01 Nov 2006    Post subject: NSR Front Wheel Q Reply with quote
hey Guys just a quick question for those of you with knowlage of the NSR front wheel, she's an 02 NSR125R with 30+K miles on it the bearings are origional on it,
yesterday the front wheel began to get skittish as if its run over a small pebble or got somthing stuck in the tread, this morning after riding it again this 'knock' or 'kick' was more pronounced on left turns, I have put it up on a front paddock stand and there is about 0.5 - 1 mm of play latteraly on the wheel, i have tightened the forks to make sure it wasn't a loose spindal and that had no effect, the wheel also began to squeek on another ride out so i know the bearings are on their way out,
the question is, i know i can knock them out with a punch but what side am i knocking from? do i want to be going in from the disk side? (i know the speedo bracket plate is there to turn the spedo so i presume thats fixed to the rim.
any advice on removing these bearings will be great Thumbs Up
A scientist crossed a skunk with an owl. He's got a bird that smells but doesn't give a hoot Smile
Paddy Blake
PostPosted: 23:03 - 01 Nov 2006    Post subject: Reply with quote
You use a bar and knock them out from the opposite side but you must
move the bar around to get them to come out level.So to remove the
left one you put the bar in the middle of the right one you know what
i mean.To put the new ones in do not hit the middle of the bearing.Use
a socket the size of the outside of the bearing and make sure it goes in
level.
Paddy.
moonym20
PostPosted: 23:13 - 01 Nov 2006    Post subject: Reply with quote
cheers Paddy Thumbs Up
im using a socket as a punch the same size as the inside ring, they are prooving to be a right pair of bastards to move, the dust seal on the non-speedo side is mince meat now Evil or Very Mad i cant get it to shift and the screw driver has chewed it up Evil or Very Mad i think its needs replacing anyway as it seems in bad shape
im hammering like mad with the sets of bearings and im getting very little play from them.
so its a case of just whack the hell out of the opposite side till the bugger drops out then work away on the other side?
thanks again
,goes back to workshop and gets hammer out...again.. Twisted Evil )
Paddy Blake
PostPosted: 23:34 - 01 Nov 2006    Post subject: Reply with quote
Yes but you got to rotate,move around to make they come out level and
dont go side ways or it can damage the wheel.
moonym20
PostPosted: 23:41 - 01 Nov 2006    Post subject: Reply with quote
thanks for the advise Thumbs Up so far as i can tell at the moment they are comming out in equal amounts.
Is it normal to hammer the hell out of them to get them to budge? i have checked my bikes maintenance reccords since it was bought and there is no reccord of the bearings ever being replaced, i got the seal off the suspect bearing and half the train was missing I only had 9 bearings left in there, there others were long slithers of metal Shocked
am i best off to just forcefully remove the rubber dust deal on the non-speedo side... its shagged anyway.. i am just wondering if there is a particular technique to getting it out
Paddy Blake
PostPosted: 23:45 - 01 Nov 2006    Post subject: Reply with quote
when you are knocking the bearing out it will knock the seal out.
moonym20
PostPosted: 23:46 - 01 Nov 2006    Post subject: Reply with quote
thanks again Thumbs Up
i've given up for the night but i will attach the bugger again tomorrow and see how i get on
appreciate the help again Thumbs Up
The last post was made 19 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.76 - MySQL Queries: 13 - Page Size: 53.31 Kb
