My new (old) Jawa
PostPosted: 19:43 - 21 Oct 2006    Post subject: My new (old) Jawa Reply with quote
I was given a free bike about a week ago. A Jawa 350 that had been stripped for painting then left disassembled for quite a long time.
It's a bog basic 350cc 2-stroke twin made in the Czech republic to an aincient design. Built as cheap and easy to maintain transport for comunist factory workers.
I was given it because the guy at the bike shop had been lumbered with it and didn't know what to do with it (other than throw it in a skip). Even running, it is probably not worth more than £200. He remembered I used to have one though so he called me and asked if I want it. Well, "Would you like a free motorbike?" has only one real answer.
Had a proper go at it today. I found a tax disc dated 1996 in one
of the boxes of bits so it is fair to assume that is the last time it
was on the road.
Done a couple of bits and pieces through the week, mostly cleaning out the fuel tank that was, against all probability, spattered with
concrete and bits of stone chippings all over the inside.
It came with two boxes of bits. On closer inspection, it would appear that most of them have nothing whatsoever to do with this bike.
As usual, someone has been 'at' the wiring so I had all that to sort
out. Tried for an oppertunist spark, no go.
After about two hours of going through all the wiring, replacing the
HT leads and cleaning up the terminals (which were covered in a
varnish-like substance) I tested the points with my multimeter. No
power going through them when closed, mighty suspicious.
Removal of the points revealed them to be covered in the same, varnish like substance. A quick file and we have sparkage. Set them by eyeball for the meantime.
Well. I cleaned out the carb earlier so bolt it on, fit the fuel tank
and have a bash at it. After about ten kicks we have signs of life,
another ten and it fires up. Running on both pots and pretty quick off the throttle. Can't get it settled to idle yet but it needs the timing doing, the pilot screw setting and the airbox refitting so there's time yet.
Most of the lights work too, well, those with bulbs in do anyhow. The flashers don't work but then they never do on these bikes, I'd say the longest I've had the flashers working on a Jawa is a week.
Got to refit the mudguard, some bits of bodywork, make a clutch cable and find some way of fitting brake switches to it and we should be ready for an MOT.
The aim tomorrow is to get it in a state that I can ride it up the road because I have a bet on with a guy from my local that I wont have it running by Sunday evening. I intend to park it on his front doorstep and blow smoke through his letterbox.
Why do bikes i buy always have the wiring buggered about with?
https://i48.photobucket.com/albums/f216/stinkwheel/wires.jpg
They know what chrome is for in Czechoslovakia, to prevent rusting, not decoration like the Japanese think
https://i48.photobucket.com/albums/f216/stinkwheel/side.jpg
As it arrived
https://i48.photobucket.com/albums/f216/stinkwheel/left.jpg
Resurrection
Ballast Boy
PostPosted: 20:25 - 21 Oct 2006    Post subject: Reply with quote
Still reckon you will win your bet?
One day left mate
Res
ZX9r
Aikman666
PostPosted: 22:22 - 21 Oct 2006    Post subject: Reply with quote
Good luck Stinkwheel, i wish my new project had the simplicity of an ancient 2stroke Laughing
Will work for petrol
My Design Blog
PostPosted: 00:57 - 22 Oct 2006    Post subject: Reply with quote
One day left mate
Res
Aye. No bother. I only made the bet on Friday night. It might not be pretty, but it'll make it 200yds up the road under its own steam.
Aikman666
PostPosted: 03:33 - 22 Oct 2006    Post subject: Reply with quote
Stink if push comes to shove just make yourself a minature circuit that will bypass all of the electronics you dont need. If i remember correctly all you need is the cable from your generator -> rectifier -> ignition coil yes? Should only take you a few minutes to make that one up Wink
My Design Blog
PostPosted: 12:31 - 22 Oct 2006    Post subject: Reply with quote
Not quite as simple as that with a Jawa. It has a pretty complex charging system which all has to be working to get a spark out of it.
That said, the point is moot, because I had the engine running yesterday so it's all over bar the shouting.
Off to have another go at it now (set up timing and carburettion, bolt on bodywork etc).
PostPosted: 18:21 - 22 Oct 2006    Post subject: Reply with quote
Well. That's me just back from the first road test Very Happy .
Runs well. Managed to get it to idle, the ignition timing was WAY out. Doesn't look like the timing has ever been touched because the stator plate screws are unmarked. The points are well worn, nearly couldn't get it timed up at all, it is at the absolute limit of the slots.
I love the simplicity of the thing though. The timing is a good example. You just stick a vernier down through one of the plug holes, find TDC then wind it back 6mm, that's your timing point. Then you just set the points to lightly grip a cigarette paper at that point. Repeat for the other set of points at 6mm back from BDC and you're done.
Needs a few new cables, they are pretty sticky and the handlebars are bent. I have a spare set of motocross bars in the lockup so I think I'll fit those and get a couple of lever assemblies from the breakers. The standard levers are pretty shite anyhow. With luck, I will find a front brake lever that takes a brake light switch and kill two birds with one stone.
Even got the flashers working after a fashion. The relay is knackered so they don't actually flash but the bulbs all light up.
This one pulls really well, I was surprised, really shoots off the mark and I had a respectable 70mph out of it on my wee test run. Didn't dare do any more just now because the brakes aren't exactly what you would call 'working'. A new cable and japanese lever assembly should make all the difference though.
Well chuffed with it. I took some pictures but my camera is on the blink.
colin1
Captain Safety
PostPosted: 20:01 - 23 Oct 2006    Post subject: Reply with quote
stinkwheel wrote:
Aye. No bother.
shouldnt that be, Aye, Nay bother ?
sounds nicer to my ear anyway
nice project, interesting read, even if i dont understand much of the technical stuff
PostPosted: 20:49 - 02 Nov 2006    Post subject: Reply with quote
Well. Booked it in for an MOT tomorrow.
I've fitted Kawasaki levers with span adjusters in place of the original ones. This has made a world of difference to the brakes (I flipped over a clutch lever for the front brake and am using the idiot switch as a brake light switch). It is actually worth using the front brake now and the cultch lever springs back all by itself (this is significant progress).
Just need to fit a flasher relay for the MOT.
So far I have had to spend money on the following:
Stuff to clean the tank £5
New brake cable £8
New points £10
Air filter £8
Gearbox oil £9
Homemade clutch cable £2
Horn from breakers £5
Rear brake light switch £3
Fork oil £10
So, £51 spent and ready for the MOT. Just added it to my insurance for a tenner.
It'll need two new tyres though.
Gazdaman
I did a trackday!!!
PostPosted: 00:34 - 03 Nov 2006    Post subject: Reply with quote
£20 says you can't finish the weston beach race on it.
Gaz
PostPosted: 16:00 - 03 Nov 2006    Post subject: Reply with quote
Passed the MOT with just an advisory on the rear tyre (absolutely on the wear limit). Got myself a good MOT man "There's a tiny bit of play in the rear wheel bearings, but only if you look for it."
Had three people flash me on the way home because they found the quantity of smoke emenating from my motorcycle disturbing Mr. Green .
Trouble is now, I don't have a V5 for it yet and there is no longer a mechanism to tax a vehicle without it (there used to be). So I have to wait for the DVLA to get their finger out of their arses before I can tax it. This is progress?
Torque05
PostPosted: 19:56 - 03 Nov 2006    Post subject: Reply with quote
Ah Rolling Eyes going to be taxed early next year then. Laughing
Joe Thumbs Up
~Sahf East Winnah~
~Yamaha Vmax 1996~
colin1
Captain Safety
PostPosted: 22:49 - 03 Nov 2006    Post subject: Reply with quote
nice to see a frail old bike nursed back to health
cqueen
PostPosted: 23:14 - 16 Nov 2006    Post subject: Reply with quote
I had one of those about 2 years ago. I tried my hardest to fix it up but the generator was screwed.
Game over.
PostPosted: 17:03 - 04 Feb 2007    Post subject: Reply with quote
Been doing some painting. Flat green with military style stencilling. Dead slapdash, just brushed on green hammerite but quite pleased with the overall result.
Sidepanels
https://i48.photobucket.com/albums/f216/stinkwheel/panels.jpg
Tank with stenciling
https://i48.photobucket.com/albums/f216/stinkwheel/tank.jpg
The finished article
https://i48.photobucket.com/albums/f216/stinkwheel/paintjob.jpg
Hopefully riding it down to the Dragon rally in Wales next weekend. We'll see if it makes it.
Whosthedaddy
PostPosted: 17:07 - 04 Feb 2007    Post subject: Reply with quote
The militarian stylee looks cool on the bike as does the white stencils, nice one Thumbs Up
Cillit-BANG
PostPosted: 18:33 - 04 Feb 2007    Post subject: Reply with quote
Fantastic job.
My neighbour absolutely loves his JAWA.
PostPosted: 23:54 - 04 Feb 2007    Post subject: Reply with quote
Shame really, cos it would have been better if it was the other major model in the Jawa range:
https://fusionanomaly.net/sandcrawler.jpg
Still, it looks great like that!
Would look cool to add a pair of jerry cans to the side on panniers as well! Smile
Sephiroth
PostPosted: 11:33 - 06 Feb 2007    Post subject: Reply with quote
I taxed my Bandit last year using the little tear off strip you get when you sign a new V5.
The bike looks quite fun, although we would need a video to prove how much smoke it's emitting. Wink
WildGoose
White Van Man
PostPosted: 20:19 - 06 Feb 2007    Post subject: Reply with quote
looking bloody awesome considering it was a free basket case Shocked
nice work sir Thumbs Up
HALUN
PostPosted: 19:19 - 25 Apr 2007    Post subject: Reply with quote
my jawa 639
https://img.photobucket.com/albums/v248/halun/my%20vehicles/042a2ad2.jpg
PostPosted: 19:24 - 25 Apr 2007    Post subject: Reply with quote
Nice colours, might have to invest in some of that green hammerite some time Thumbs Up.
Fahd
PostPosted: 16:35 - 26 Apr 2007    Post subject: Reply with quote
A 350cc 2 stroke engine?! how fast does this thing go? nice little project by the way... Smile
PostPosted: 18:31 - 26 Apr 2007    Post subject: Reply with quote
Stinky, where did you get the stencils from?
Gazdaman
I did a trackday!!!
PostPosted: 19:35 - 26 Apr 2007    Post subject: Reply with quote
Steady on there cowboy. I'm guessing you'd be lucky if this thing makes 30bhp, probably geared for 90mph top whack.
They aint quick, they're reliable.
Gaz
The last post was made 19 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.38 - MySQL Queries: 13 - Page Size: 131.28 Kb
