| Dalemac |
 Dalemac World Chat Champion
 Posted: 00:59 - 29 Oct 2006 Post subject: Gears |
Hey everyone! i passed my cbt today and got my ybr 125. im well pleased its so wicked. i think im gonna be attached to biking forever
i have got one really noobish question tho;
if you are coming to a junction in, say 3rd gear, and realise you have to change down to 1st gear, can you knock the gears down from 3rd gear to 1st gear, essentially skipping a gear? i have done this alot today as its my first day, but i want to know if i should be doing it, and if it is ok for the bike.
its probably the wrong thing to do, and i need t anticipate and plan ahead a bit more, so im in 2nd gear way before the junction.
if a am wrong can anyone please write a little sequence of what i need to be doing when i aproach a junction in a high gear.
any help would be much appreciated.
thanks,
Dale ____________________
YBR125 -> GPZ500S -> SL1000 |
| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 01:13 - 29 Oct 2006 Post subject: |
One gear per movement of the gear lever, therefore 3-2-1. ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| ncrn |
 ncrn World Chat Champion
 Posted: 01:14 - 29 Oct 2006 Post subject: |
dropping from 3rd to 1st can be bad, as if you dont bring your revs up enough you do run the risk of locking the back wheel.
Ive found when your coming up to the junction you have to just keep going down the gears, so say im approching the junction in 4th and I have to stop.
Clutch in, blip the throttle (Rev it to about the speed the engine will be turning in the lower gear), then change down gear and release the clutch.
Then do this again,
and again, and you should be in first. If you can do this whilst applying smooth front brake pressure, your better than I am
If you hve to make an emergency stop however, dont bother with the gear changing, as you need to focus on stopping ^^ ____________________ Past: 55 Sym Jet, 91 ZZR250, 03 NSR125R. Present: 97 ER-5.
https://www.nsr125.co.uk - NSR Owners forum. |
| gavin |
 gavin World Chat Champion
| stinkwheel |
 Posted: 01:26 - 29 Oct 2006 Post subject: |
The gearbox is sequential, so you can't really 'miss' a gear as such, you always change through all of them. Ideally you wouldn't 'coast' as you approach a junction, the engine braking makes you in much more control of the bike (so no rolling along with the clutch pulled in).
The official line is to 'be in the gear appropriate to your speed and engine speed' .
So from what I read you doing, you are approaching in third, braking, then changing down to first as you come to a halt. No problem providing you aren't getting excessive engine braking when you do so (ie, not changing down too far for your speed). You might find it a bit smoother if you let the clutch out slightly as you go through second so it engages the gear momentarily.
Personally, I usually find myself slowly approaching the junction in second gear so if the way is clear, I can just open the throttle again and go. If I need to stop, I snick it down into first.
Also worth mentioning. Remeber that 'slow riding' stuff they went on about on your CBT? That's probably the hardest bit when you come to do your test. It's what you do when you're doing the u-turn. Approaching junctions/lights is the ideal time to practice this, especially in traffic where it is quite useful.
If you are in traffic and know you are going to have to stop because the traffic in front of you is stop-starting, get in first as you approach the cars and go into 'slow riding mode'. See if you can trickle along dead slowly behind the traffic without coming to a complete stop. Keeps things smooth, allows you to move away quickly and is an excellent way of perfecting your throttle and clutch control. |
| Dalemac |
| stinkwheel |
| ncrn |
 Posted: 15:29 - 29 Oct 2006 Post subject: |
| Dale_Mckeown wrote: | i was on a long country road on the way back from my cbt, doin about 35, was ridin in the middle of the road, and there was a constant stream of cars overtaking me, one almost hit me. it annoys me at how inconsiderate some (well most) people are! |
Road positioning helps for this. As long as you stay more towards the right of your lane cars can't try to squeeze past you. When cars do try overtake don't make it easy for them, hold your line, (although if you are at risk by them overtaking let them go by, its better to let them do it than get injured)
And dont worry if your going slow as you ride, you paid your tax so you have the right to use the road at whatever speed you like ____________________ Past: 55 Sym Jet, 91 ZZR250, 03 NSR125R. Present: 97 ER-5.
| KTM Gordo |
 KTM Gordo Brolly Dolly
 Posted: 15:43 - 29 Oct 2006 Post subject: |
If you're going to have to stop then don't worry about changing gear on the approach - wait until you've stopped, then find neutral.
You can go down more than one gear at a time, but you have to kick the lever down twice to do it, and some 'bikes are reluctant to do it without the clutch being engaged each time.
With practice you'll get in to the the "habit" of being in the right gear at the right time, and block changes on the move shouldn't really be necessary.
HTH  ____________________ Change is inevitable - except from a vending machine.
KTM 990 Adventure | KTM EXC 250 Racing | Land Rover Freelander SE Td4 |
| Dalemac |
| palmer |
 palmer Fiddled Kiddy
 Posted: 22:35 - 29 Oct 2006 Post subject: |
you can slow the bike down by just going down the gears one by one quite a bit.
if you know the roads well, you may not need to use the brakes that much  |
| kkhalil76 |
 kkhalil76 Nova Slayer
 Posted: 15:05 - 02 Nov 2006 Post subject: |
Is blipping necessary/better than just slowing down with the brakes? At the moment I just slow down with front brake, when slow enough I pull in the clutch and click down to first.
| ncrn wrote: | dropping from 3rd to 1st can be bad, as if you dont bring your revs up enough you do run the risk of locking the back wheel.
Then do this again,
If you hve to make an emergency stop however, dont bother with the gear changing, as you need to focus on stopping ^^ |
| ncrn |
 Posted: 18:04 - 02 Nov 2006 Post subject: |
[quote="kkhalil76"]Is blipping necessary/better than just slowing down with the brakes? At the moment I just slow down with front brake, when slow enough I pull in the clutch and click down to first.
I dont find it is always neccesary, but you have to be careful as if you dont blip the throttle as you change gears, you do run the risk of locking your back wheel (I have done this before)
and of course if you do this and its wet, you could be on the floor, which isnt fun at all.
Although i have found that if I'm rolling through town and Im slowing down its not really neccesary, but when out in the countryside, or rapidly downshifting its important. ____________________ Past: 55 Sym Jet, 91 ZZR250, 03 NSR125R. Present: 97 ER-5.
| kkhalil76 |
| veeeffarr |
 veeeffarr Super Spammer
 Posted: 18:18 - 02 Nov 2006 Post subject: |
If you do blip on downchanges be careful that you don't accidentally try and blip and shift down when you're already in first... I've nearly been launched at traffic lights on my 500 because of that  |
| Louise |
 Louise World Chat Champion
| veeeffarr |
| ncrn |
| Louise |
 Posted: 22:46 - 02 Nov 2006 Post subject: |
Ok then.
I had a bit of a panicky moment few nights ago.
Going alone, duel c/way its 70mph. at the end is a hill going towards some traffic lights. They have thos cams, that if your caught going through an amber your flashed.
Anyway, the 70mph ended and went in to a 40.... By time I got the the lights i was still doing 50ish, anyway lights went,car in front slammed hard on the brakes, I had to whack my back brake which locked the wheel. I didnt even know i was skidding untill the end when I felt the bike 'wobble'. Looked back and had at least a 10 meter skid mark!
How, can I slow that quick without locking  |
| kkhalil76 |
| krebsy |
 krebsy World Chat Champion
 Posted: 12:31 - 03 Nov 2006 Post subject: |
I keep having to remind myself not to use the rear brake so much as I have a tendancy to brake hard for roundabouts, knock it down from 6th to 3rd (Blipping as I go) but too much front brake and clutch has meant a few times that the back has locked when I've touched the pedal.
Best bet (i've found) for braking hard is to use lots of front and keep the weight forward so the wheel is pressed into the floor more, then Clutch, down a cog, release clutch (with the tiniest of blips) and then repeat until 2nd gear, then start mixing in some rear brake.
Mind you, I've slid the front with too much braking before as well... .
K. ____________________ What's my New Year's resolution?
1280 x 1024. |
| Louise |
| i_am_tim |
 i_am_tim Nitrous Nuisance
 Posted: 00:56 - 04 Nov 2006 Post subject: |
can someone explain the blipping thing please? iv only been riding about a month and iv never heard of it
do you mean that when downshifting instead of letting the clutch out smoothly to move off again you increase revs? or have i totally lost the idea? thanks for helping the noob  ____________________ previous bike: 2000 Aprilia rs 125 - SOLD
current bike: 2001 Yamaha R6 - sweeeeet |
| Keyamon |
 Keyamon Two Stroke Sniffer
| Dalemac |
The last post was made 19 years, 282 days ago. Instead of replying here, would creating a new thread be more useful? |
