ns125r-k carb setup
Welshd1k
PostPosted: 12:41 - 04 Nov 2006    Post subject: ns125r-k carb setup Reply with quote
ok changed my needle for a new one and now the bike is being a bitch wont tick over properly and aint got the mid range punch any more so what setup should the screws o the side be @t ???
need help asap meant to be doign a 60 mile journey in 4 hours !!!
also the white plastic thing in the reed block do i remove this???
final one if i was to drill holes in air box what would i have to do to counter act this (been told it wont rev correctly)
thanks once again chris
Welshd1k
PostPosted: 13:24 - 04 Nov 2006    Post subject: Reply with quote
help ??? any one got the haynes or simular?
alains
PostPosted: 13:59 - 04 Nov 2006    Post subject: Reply with quote
did you set the needle on the same notch as before ?
Welshd1k
PostPosted: 15:12 - 04 Nov 2006    Post subject: Reply with quote
yes i did just put the old needle back in and still wont tick over i have had a small fiddle with the 2 scres on the side so upset it Sad any help on standard settings just for today
Marci
PostPosted: 15:22 - 04 Nov 2006    Post subject: Reply with quote
The unsprung screw - nip it up then wind it out one and a half turns. Might need up to 2 and a half to run smoothly. This is mixture screw (air : fuel)
The sprung screw - this is idle speed... get the bike running and adjust this one way to speed up the idle revs, and the other to slow em down. Want it set to about 1400rpm if memory serves correct for that bike.
If you drill the airbox you'll have to go up on the jet sizes or you'll run lean and risk siezure.
What white plastic thing?
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
Welshd1k
PostPosted: 15:23 - 04 Nov 2006    Post subject: Reply with quote
ta will do so right now Very Happy
Welshd1k
PostPosted: 15:37 - 04 Nov 2006    Post subject: Reply with quote
grrr the idle screw seems to be doing verry little what position is the needle bottom?
alains
PostPosted: 15:41 - 04 Nov 2006    Post subject: Reply with quote
on the 2nd notch from top (set 25 on 2nd notch of 24)
Welshd1k
PostPosted: 15:46 - 04 Nov 2006    Post subject: Reply with quote
what does having it down so low do Question so i might aswel put the old needle back in as that might be the problem also hile i am at it the white block int he reed valves worth removing?a nd adding extra airflow can it be done with the jets i have (something for me to do tomorrow)
Welshd1k
PostPosted: 15:47 - 04 Nov 2006    Post subject: Reply with quote
also the needle go's inside the cylinder thin not beneath liek in the pic correct
alains
PostPosted: 15:51 - 04 Nov 2006    Post subject: Reply with quote
about the plastic block in the reeds , do not remove it's a guide for the intake mixture
Welshd1k
brb will be 10 mins max Twisted Evil tank of flying job Very Happy
Welshd1k
PostPosted: 16:13 - 04 Nov 2006    Post subject: Reply with quote
back Very Happy
ok need to go get pertol now ran out
but the idle seemed to do verry little difference Mad
alains
PostPosted: 16:21 - 04 Nov 2006    Post subject: Reply with quote
pilot screw 2 1/2 turns out
idle screw 1400 rpm +- 100
air box filter well cleaned
Welshd1k
PostPosted: 16:37 - 04 Nov 2006    Post subject: Reply with quote
revs are hangign now and if you give it a fist full of revs from idle it stallss Evil or Very Mad damn machine
alains
PostPosted: 18:19 - 04 Nov 2006    Post subject: Reply with quote
set idle at 1500
The last post was made 19 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 84.43 Kb
