| LanaTheGreat |
 LanaTheGreat Scooby Slapper
| LanaTheGreat |
| Cillit-BANG |
 Cillit-BANG World Chat Champion
 Posted: 17:04 - 05 Nov 2006 Post subject: |
Do a search on google for wheel building/trueing.
It is a fine art but the basics can be picked up easily. Basically the spokes create the tension which keeps the rim true. Bending the rim back by brute force will as a result create an area of loose spokes and won't help the problem.
If you look at the wheel, there are spokes which lead off to either side of the hub. Tightening these spokes will pull the rim over to this side of the hub. So trace the spokes back to the hub where the wheel is buckled and tighten those individual nipples (you'll need a spoke/nipple key and are available in different sizes depending on the guage of the spokes).
You need to be carefull though as the wheel is in balance and altering this by tightening certain spokes and not others will have a affect on the overall shape of the wheel. Also, as well as tightening the loose spokes, you may also need to loosen the tight ones. The wheel is in tension to keep the rim straight, but also a true circle and not an egg shape.
As I say, it is quite simple but also quite complicated
Wheel building from scratch is very satisfying. I used to build push bikes wheels and these are even more critical to get right as minute changes at the nipple can affect the whole shape and tension of the wheel. Weight for size etc. a well built mountain bike wheel is one of the strongest manmade structures on earth.
I suspect that there will be a wheel builder in a local town somewhere. You may find that if the rim is actually damaged then no amount of re-tensioning will help. |
| hmmmnz |
 hmmmnz Super Spammer
| Paddy Blake |
| LanaTheGreat |
 Posted: 20:12 - 05 Nov 2006 Post subject: |
Thank you so much for your responses. I am going to check out that website to see if it will help solve my problem. Does anyone perhaps know what the problem regarding the scooter might be? I was wondering if it could be wheel alignment, as I read on a website while searching the solution that even bikes need wheel alignment (see https://www.motorcycle.com/mo/mcnuts/chassis.html for details). I found that quite interesting. |
| Walloper |
 Walloper Super Spammer
 Posted: 21:06 - 05 Nov 2006 Post subject: |
You can find a Floppy in Soweto will do a fine job on your wheel.
20 Rand. Danke manure Duwus  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| LanaTheGreat |
| Walloper |
| LanaTheGreat |
| Walloper |
 Posted: 00:15 - 07 Nov 2006 Post subject: |
Coz you is on the land of their ancestors shite......
If everyone was like that then we could kick the English out and take the Oil here for ourself.
But we really like the Pommes sort of..
I used to true the wheels of my mountain bike.
It takes a while no matter what way you do it. It's a labour of love though.
But not too difficult.
You will need to make some kind of Jig to stand the wheel in. And buy a Spoke key. Do not over tighten the nuts or you will make it worserer. Search the net for a HOW DO I?
Good luck with the wheel. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| LanaTheGreat |
The last post was made 19 years, 204 days ago. Instead of replying here, would creating a new thread be more useful? |
