chain to big (wide) for sprocket?
Keir
PostPosted: 11:12 - 07 Nov 2006    Post subject: chain to big (wide) for sprocket? Reply with quote
I was servicing my fazer last night and grabbed the sprocket to make sure it was tight etc when i noticed the chain seemed quite a bit wider than the sprocket itself. Is this normal or has the previous owner bought the wrong replacement chain?
Its an aftermarket DID chain on standard yamaha sprockets. I tried to look for the 525, 530 etc on the chain but couldnt find it.
Current : '08 Yamaha FZ1s
Bezzer
PostPosted: 11:49 - 07 Nov 2006    Post subject: Reply with quote
Probably is OK but just to make sure - 5 means it's 5/8" rivet to rivet on the side plates (centres of the rollers), the next number is the roller length in 1/8ths" so 2 = 1/4", 3=3/8"
So 530 and 520 have the same side plates, the 530 is 3/8" width across the rollers and 520 is 1/4" across the rollers.
If there is a problem it will be you have 520 sprockets and a 530 chain.
The last post was made 19 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 31.8 Kb
