| Feasty |
 Feasty World Chat Champion
 Posted: 11:09 - 07 Nov 2006 Post subject: Which way to turn! |
I've got a Yamaha SR125 but am still not 100% sure which way to turn the mixture screw underneath the carb to make it leaner or richer. Anyone any ideas?
I've always assumed undoing (anticlockwise) makes the bike run leaner, even the Haynes manual I have doesn't make it very clear which way to turn...  |
| feef |
 feef Energiser Bunny
| Feasty |
 Posted: 12:00 - 07 Nov 2006 Post subject: |
Idle mixture screws need adjusting 1/8 of a turn at a time. If you turned it 2 turns then you have some other problem, unless it was already turned too far out and running as rich as possible.
Also, a lot of people don't realise that the adjustment screws only affect very low-speed running. It won't affect the main mixture or help with fuel economy much at all. The biggest effect on fuel economy is needle height imho. ____________________ a.k.a 'Geri'
| KatOwner |
 KatOwner Nova Slayer
| Feasty |
 Posted: 10:31 - 08 Nov 2006 Post subject: |
I was having specific problems that I've now solved, however this is something that has been bugging me for a while and I've never been 100% certain which way turning the bugger does what!
Turns out from previous posts I've been thinking it worked the opposite to how it actually does, but I still had it about 1 turn out from fully closed and that seems fine.
I was also curious as last night I had another fiddle (like you do!), and discovered I had to unscrew the screw about 4 turns before the tickover started being more erratic and eventually dying. However with the screw fully closed the bike runs exactly the same as if the screw is unscrewed by 1 turn. I'm trying to work out if this means some jets are slightly blocked etc, or wether it's just because it's a 12 yr old bike and not as responsive to changes as it used to be in its heyday!
Any ideas?
The last post was made 19 years, 246 days ago. Instead of replying here, would creating a new thread be more useful? |
