| paulodd |
 paulodd Crazy Courier
 Posted: 13:52 - 07 Nov 2006 Post subject: R6 engine - gearbox problems.... |
Need some advice/help.....
I have a 1999 R6 thats done just over 14k, the problem is... i knock it into 2nd gear, it goes in and then when i wind the power on at about 8-11k revs it jumps out of gear and back in.
I know that older R6s are prone to a screwed 2nd gear but i didnt expect it only after 14k miles!
After speaking to a few people its been narrowed down to 2 problems.....
Bent fork selector
Worn dogs
The plan was to pick up a cheap engine off ebay and swap it over myself with a couple of mates BUT after looking through ebay R6 engines go for stupid amounts!!!!
This morning i was chatting to a mechanic and he said that if i were to drop the engine, and take it to his he would change the gearbox over and then i would put it back in the bike.
Does this sound like a good or bad idea? Afterall it'll fix it although i wont have any history of the engine.
Another annoying point is i'm meant to be doing Brands on the 25th of this month
Any suggestions / advice??
Paul ____________________ Paul
1999 Yamaha R6
www.coventrybikers.co.uk / www.norfolkriders.co.uk |
| dave1rs |
 dave1rs Trackday Trickster
 Posted: 20:17 - 07 Nov 2006 Post subject: |
From the symptoms it sounds like worn dogs. ____________________ a.k.a 'Geri'
| Wooly R6 |
 Wooly R6 World Chat Champion
 Posted: 22:18 - 07 Nov 2006 Post subject: |
woof woof  ____________________ R6 has been sold - 2004 Honda VFR VTEC now sold too - no bike at the moment |
| Paddy Blake |
| MattEMulsion |
 MattEMulsion World Chat Champion
| paulodd |
 Posted: 23:34 - 08 Nov 2006 Post subject: |
cheers everyone for the input!
I think im going to try and pick up a cheap engine, and just do a straight engine swap.
Cheers MattEMulsion, have just signed up on that site
1999 Yamaha R6
| Paddy Blake |
| paulodd |
| 0ddball |
 0ddball World Chat Champion
 Posted: 11:04 - 09 Nov 2006 Post subject: |
So swapping one problem for another What if it's not as simple as replacing the gasket, the head might be warped too, it might not even be the problem.
And seeing as 2nd gear is a common weak point it's possible that any replacement engine could have the same problem.
It's astounding that someone would fit another engine rather than do a cheap and fairly easy (albeit time consuming) fix on their existing one. |
| Blau Zedong |
 Blau Zedong Banned
| paulodd |
 Posted: 12:57 - 09 Nov 2006 Post subject: |
| SpannerMonkey wrote: | So swapping one problem for another  What if it's not as simple as replacing the gasket, the head might be warped too, it might not even be the problem.
Like Bluex5 just said its not an easy job to do! And there are alot of things that could go wrong if you cock up. So the way i look at it is....
Get another cheapish engine, and swap them over. Then sell my engine with the problem to make some money back.
Also to change the gearbox its still going to cost a fair bit. Theres the fork selector and dogs on ebay but the BIN price is still £150. so do i buy a gearbox for that and then have to swap them over which is a massive job or just swap an engine over for the same price.
IMO its easy and quicker to swap a whole engine over than dropping mine, taking it apart, changing the dogs, putting it back together, then putting the engine back in.
But yes your correct about the engine with the blown gasket. I probably wont buy it.
Cheers for the input tho ____________________ Paul
1999 Yamaha R6
 Posted: 16:08 - 09 Nov 2006 Post subject: |
I might know where there's some gearbox bits. A lad at work races them. I'll ask him for you. Stripping and rebuilding a modern inline-4 isn't as difficult as you would believe. Manufactuing proceedures and tolerances mean that the easier it is to build, the cheaper it is to manufacture. I could easily change out the gearbox in an afternoon, not including actually getting the engine out of the bike. ____________________ a.k.a 'Geri'
| sickpup |
 sickpup Old Timer
 Posted: 18:39 - 09 Nov 2006 Post subject: |
Even better, 'busas are the same no need to touch the top-end. I'm sure they did it deliberately. ____________________ a.k.a 'Geri'
| MattEMulsion |
 Posted: 07:13 - 10 Nov 2006 Post subject: |
The symptoms don't point to a broken detent spring. If it were the spring broken/stretched, then a likely symptom would be poor gear selection or jumping instantly out of gear and once jumped out being difficut to re-select, this is because the index lever isn't holding the pins in the right place for the pawl to catch them and turn the shift drum.
His symptoms are classic worn engaging dogs. ____________________ a.k.a 'Geri'
| MattEMulsion |
| craigT19 |
 craigT19 Jolly Green Giant
 Posted: 18:07 - 11 Nov 2006 Post subject: |
as sick pup said its easy to get to the R6 gearbox, engine out, flip over, sump off, lower case off "and there she be!" ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003 |
| craigT19 |
 Posted: 18:57 - 14 Nov 2006 Post subject: |
paul as per your pm to me.
the stuff you should take out of your donor box is both gear shafts, the selector drum and the selector forks, also the forks run on 2 shafts....take them too, and they have springs on the end of them that go into the cases first to stop the shafts from rattling...make sure there in good order.
also on the end of the first shaft (on the left hand side as u look at it) inside the bearing is a polished metal washer about the size of the bottom of a cup....make sure its not warped and try to keep the original one if its ok
1. install the primary gear shaft,slide it into the case and push the polished washer onto the output shaft bearing
2.drop the selector fork into its grove on the shaft spin it around and slide the shaft that holds it into place (spring first )
3. install the drum locating the first fork.
4.locate the final 2 forks into the drum and slide the shaft in
5.then fit the final row of gears, slotting the forks in
should work fine but its worth doing this check.....
on the left hand side of the (clutch) gears shaft your se a small brock of metal spin the thing till that block of metal is facing towards u (if u look closely your see a little switch, thats your neutral light switch, the block simply pushes it.
u should now me in neutral, hold the output shaft (where the front sprocket attaches) and spin the other shaft (by the splines the clutch basket mounts onto),it should spin freely
if it does job done your in neutral, just click through the gears making sure it selects them all and it should work fine
hope this helps ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
| paulodd |
 Posted: 23:05 - 15 Nov 2006 Post subject: |
Cheers craig!!!
Will give that ago. Althlough wont be doing it till next month now. but thanks for the info!!! highly appreciated!
If it goes wrong i'll hold you too it nah, thanks tho ____________________ Paul
1999 Yamaha R6
The last post was made 19 years, 43 days ago. Instead of replying here, would creating a new thread be more useful? |
