anyone know anything about airbrushing?
beatnck
PostPosted: 21:50 - 08 Nov 2006    Post subject: anyone know anything about airbrushing? Reply with quote
ive been thinking about learning how to airbrush, but i know near enough nothing about how to start..i.e what equipment do i need/is best etc etc.
im going to get a book to learn the basics, but if anyone can give some advice it would be appreciated Thumbs Up
daz|n00by
The Internet
PostPosted: 22:04 - 08 Nov 2006    Post subject: Reply with quote
i could help you out but tbh i dont have time to do a write up atm.. i have been learning airbrushing for a couple of years and unless you have a lot of time to sit and practice then your on a bad start .
basics are
you will neeed a compressor that will give you a steady flow no more than about 40 psi, it needs a inline water trap and a adjustable pressure gauge.
you will need a lot of practice materials depending on what you want to spray ie panels, canvase, paper.
you will need to get the paint for the type of spraying your doing as above. if you think using one type of paint is the only way it works ge tused to the idea that it costs a lot of money for bike and helmet spraying as different paints are needed for different affects, ie pearl, opaqe, transparent, candy, thinners are needed and lots of mixing containers.
the the important part is the airbrush its self. the more money you can throw at a airbrush the better your work will be, i have 5 airbrushes and they are all used when i can be bothered to do some painting. good makes are iwata, devilblis.
ebay is a good source for starting cheap, just type in airbrush inthe search box and loads of stuff pops up.
a few links for yopu ..
https://www.katewerk.com/stepbystep.html
https://www.howtoairbrush.com/Lindex.htm
https://www.airbrushing.ca/
https://www.airbrush.com/how-to-guide.aspx?content=how-to/howtoDetail&id=37
forums work wonders for ideas and insperation ...
https://www.airbrush.com/forums/tt.aspx?forumid=2
https://novogate.com/exco/index.php?boardid=483
https://www.pastranaunlimited.com/scrngif/teeveeal/index.htm
https://bobfalconer.co.uk/index.htm
https://www.airbrushfitto.com/en-main.html
those should keep you busy for a night .
"Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class. Smile
bandit kev
PostPosted: 22:13 - 08 Nov 2006    Post subject: Reply with quote
i have been thinking about trying some airbrush work been looking on ebay for it all so you could try there
if it's not broken then don't fix it
beatnck
PostPosted: 23:27 - 08 Nov 2006    Post subject: Reply with quote
thats great, cheers guys Thumbs Up given me a lot to work with there Smile
The last post was made 19 years, 346 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 41.59 Kb
