odd thick black oil leaking from left hand side
i_am_tim
PostPosted: 16:00 - 08 Nov 2006    Post subject: odd thick black oil leaking from left hand side Reply with quote
hoping you guys can help, i have been having a few drops of this really thick black oil driping out of the left hand side of my bike (rs125) every night recently, any idea what it couold be? i dont know what oil it could be from, i didnt think it was 2stroke oil though because its so thick and and pitch black
any idea as to what it is and how to stop it? thanks for any help!
previous bike: 2000 Aprilia rs 125 - SOLD
current bike: 2001 Yamaha R6 - sweeeeet
finpos
PostPosted: 16:20 - 08 Nov 2006    Post subject: Reply with quote
Could be good old fashioned crap dribbling off your chain.
finpos.
i_am_tim
PostPosted: 16:59 - 08 Nov 2006    Post subject: Reply with quote
nah, its coming from under the fairings
Walloper
PostPosted: 17:05 - 08 Nov 2006    Post subject: Reply with quote
It's thick black Ooze.
It means the fairing needs to come off.
No luck. Sad
cestrian
PostPosted: 18:31 - 08 Nov 2006    Post subject: Reply with quote
Thick and pitch black sounds like oil which is full of carbon. I guess you'll be checking your exhaust first. (I am assuming that the bike is well maintained)
Gordon
i_am_tim
PostPosted: 19:28 - 08 Nov 2006    Post subject: Reply with quote
okay, iv taken the fairings off and their was oil all over the front of the transmission casing, so iv cleaned it with a pressure washed and cloth to try and see where its coming from, looks like its leaking out of the casing, see below
https://img.photobucket.com/albums/v626/i_am_tim/IMG_0628.jpg
does this mean the seals need replacing? or is there something less drastic that can be done? im starting to worry about seizing gears now..... Shocked
Walloper
PostPosted: 19:40 - 08 Nov 2006    Post subject: Reply with quote
Get some gunk into that and get it 'clean'.
Check fluid levels.
Run it till it's warm and dry.
Look around the engine with a good light source.
Try spraying the joints with a Dry Deodorant spray to show up wet patches.
But you will need to take time to clean it. Properly.... Evil or Very Mad
We have rules about dirty Kit on this forum Laddie. Laughing
Has the engine been 'cooked'?
i_am_tim
PostPosted: 19:47 - 08 Nov 2006    Post subject: Reply with quote
yeah thats a before pic.....
its not exactly sparkling now, but its better than that
nah its hasnt been used more than before, i always let it warm up properly before using it, i mean a few drops of oil wouldnt worry me if it wasnt the fact that the gears could seize
THCi
PostPosted: 22:54 - 08 Nov 2006    Post subject: Reply with quote
Jet washing over a gasket can never be good. Might have caused the problem in the first place.
Past: GZ 125 K4 Marauder, VL 125 LC Intruder, FZS 600 Fazer. Present: GSF 600 N K3 Bandit, GSX-R 600 X(soon)
"We're not gonna die. We can't die, Bendis. You know why? Because we are so...very...pretty. We are just too pretty for God to let us die."
i_am_tim
PostPosted: 00:04 - 09 Nov 2006    Post subject: Reply with quote
i only just did it after i noticed the problem
anyone know a decent supplier for gaskets?
Paddy Blake
Is there a power valve type thing on the front of the cylinder at the
exhaust port that might have a blown seal.
i_am_tim
PostPosted: 00:23 - 09 Nov 2006    Post subject: Reply with quote
yeah it had a power valve, no idea on the blown seal, i'll take it out tomorrow and have a look, thanks for the input guys!
Walloper
PostPosted: 10:29 - 09 Nov 2006    Post subject: Reply with quote
With respect Sir, If the gasket is 'sound' then a normal 'going over' with a jet wash won't do any harm.
I agree directing the jet straight into the joint between the mating surfaces would not be the most wise-est of practices.
The most important agent is an effective and safe solvent.
This will emulsify any crap without harm to machine or human or our fagile environ. Karma
ddracer
PostPosted: 15:05 - 09 Nov 2006    Post subject: Reply with quote
Hi there,
That is gunk leaking from the power valve assembly. Inside the valve housing the is a valve stem seal as the valve and seal wear it starts to leak, just change it and all will be ok. It's also worth cleaning the valve blade as this will improve engine response.
DD
quik_d
PostPosted: 12:38 - 11 Nov 2006    Post subject: Reply with quote
ddracer wrote:
Hi there,
DD
Second that theory, thats what mine did Thumbs Up
LOOK AT DAT M8 WELL LUSH A PARROT INT IT
The last post was made 19 years, 241 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 84.31 Kb
