| alien.46.uk |
 alien.46.uk Could Be A Chat Bot
 Posted: 21:20 - 09 Nov 2006 Post subject: Overheating in This Cold Wether in Ques ( ... Still!) |
Hi there all, haven't posted on here for a while as I've been out running my bike in, got 411Km on the clock in no more than a month ...
But since I've been using it to college and had the usual cues to deal with and not yet braving the world of filtering I've noticed that my Cooling system still isn't quite right.
Before my issue was overheating just idling but Kickstart worked out that was due to the Wrong sensor being in.
But this is after say a 15/20 ride. At the start i don't hit cues so it moving and sits at 60* which is also 20* under the best running temperature.
Then when im sitting in a cue of traffic within say 4 - 5 minutes im past 80* with it still on the rise.
Got stuck for a good 10 minutes once and was virtually in the Red just before i managed to get moving a little bit ...
I know you might say, well start filtering then, but i haven't built the courage yet ...
Also to those who say to take the stat out, i know the system is working due to the similar heated Rad. Also with the stat out it might become even more of a pig to start in the morning than it is already ... Also, when Kickstart and I tested it, the Stat and Rad system is working fine.
Its idling at around 4-5k, but that's due to some suspected broken seals allowing some gearbox fluid into the engine running with some air.
Could this high idling be almost running the engine too much and over-heating that way?
I'm going on a Big Charity Ride out on Saturday up near Manchester with 700+ Bikers, so have a good long run then, but im afraid that with the amount of bikes and police escorts etc, im going to get held up or at least not move too fast ... And im afraid of overheating at that point.
How about if i was to let the clutch out a tad and lower the revs whilst in cues, not enough to move, but i can let it out enough to get the revs back down to near 2k ...
Hope someone can help,
Luke. ____________________ 2007 Kawasaki ZX10R :: 1998 Kawasaki ZX-9R - SOLD
1998 Yamaha FZS600 Fazer - SOLD :: 1994 Aprilia Pegaso 125 - SOLD |
| alien.46.uk |
 Posted: 21:37 - 09 Nov 2006 Post subject: |
As i wrote that I've reminded myself, so that'll be done tomorrow ...
It feels fine and smooth unlike when it was dry, so i think there's some gunk in there, but there's certainly less in there than when i started, just got to have a guess at how much ... Not so easy when it's all based on taking a bolt out and not having a level viewer to see ...
So, there high Idling would cause the quick heat build up?
I think it idling that high is helping run it in though, hehehe ...
I'm soo close to being happy with it again, just got this heat issue.
| Walloper |
 Walloper Super Spammer
| finpos |
 finpos World Chat Champion
| Finglonga |
 Finglonga World Chat Champion
| alien.46.uk |
 Posted: 21:57 - 09 Nov 2006 Post subject: |
| alien.46.uk |
| hmmmnz |
 hmmmnz Super Spammer
| Blau Zedong |
 Blau Zedong Banned
| alien.46.uk |
 Posted: 00:09 - 10 Nov 2006 Post subject: |
EDIT as Blue posted whilst Typing :
As to the Piston Melting when under load, I've had it under load going up this damn huge hill up to college. When accelerating and running and sometimes pushing it a bit ... It's absolutely fine ... No over-heating whilst running and moving ...
____________
Right ... I'll check the Gearbox Level Tomorrow ...
And i'll double check the Rad level but it was completely filled about 4 weeks ago, so should still be the same and before anyone says ... yes i got all the air of the system] ...
My next note is that I bought a Chain a Sprocket Kit "For my Bike" only to find (Admittedly opening it about 2 months after buying it) to find that the Front sprocket is Totally wrong. The on on there is in pretty good nick so i "was" going to change the Rear Sprocket and Chain ...
Then I've now found that the IZUMI Heavy Duty O-Ring Chain in the Set has 114 Links. I was under the assumption mine didn't use O-Ring and also it was 104 Links ...
What can i do in this situation as I can no longer get hold of the Company on Ebay and cant find them, plus it was 2 Months + ago ...
Thanks,
 Posted: 00:24 - 10 Nov 2006 Post subject: |
What is wrong with the front sprocket?
With the chain you can just take a few links out to shorten it if necessary. Just don't take too many out!
O ring chain will last longer. In theory will absorb slightly more power than a conventional chain, but in practice tha difference will be tiny (and give it 10000 miles and the O ring chain will be in far better condition so absorbing less power).
However I would check you have the correct rear sprocket as well, rather than a kit for some other random bike.
| alien.46.uk |
| alien.46.uk |
| Marci |
 Marci Brolly Dolly
 Posted: 12:52 - 10 Nov 2006 Post subject: |
Invest in a 120mm PC Cooling fan, a switch, some wire, and some zipties.
Attach aforementioned fan to radiator with aforementioned zipties.
Attach aforementioned switch to bars or headstock.
Splice it into a 12v line.
When you notice temps hitting painful levels whilst queuing, switch on fan.
That's the quickfix whilst you find out the actual cause. ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk |
| Walloper |
 Posted: 12:55 - 10 Nov 2006 Post subject: |
FIRST | Marci wrote: | Invest in a 120mm PC Cooling fan, a switch, some wire, and some zipties.
BUT THEN.....
That's the quickfix whilst you find out the actual cause. | Phew....  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
The last post was made 19 years, 240 days ago. Instead of replying here, would creating a new thread be more useful? |
