fitting an alarm
salty21
PostPosted: 18:03 - 10 Nov 2006    Post subject: fitting an alarm Reply with quote
thinkin about buyin a bike alarm/immobiliser off ebay just wondered if they are tricky to fit. i have little wiring experience but am not scared of having a stab at it any tips would be appreciated
thanks
Finglonga
PostPosted: 20:54 - 10 Nov 2006    Post subject: Reply with quote
Depends which one you get. Cheap ones are easy to wire up and easier to bypass. The more expensive ones are better as all wires out of the alarm unit are the same colour with just labels on(you remove them when you fit it), but are much harder to fit if you don't know what you are doing.
Andy Sez....
F.Y.Y.F.F.
Ichy
PostPosted: 22:46 - 10 Nov 2006    Post subject: Reply with quote
Cheapest will have two wires and take minutes to fit.
Basic immobiliser type have about 5/6 wires and take a couple of hours. The important bit is to have a good think of where its all going before you start.
Any idea which type your going for?
PostPosted: 23:07 - 10 Nov 2006    Post subject: Reply with quote
A badly-fitted immobilier/alarm can cause nightmares. If it's a simple device that doesn't cut into the wiring for immobilising the bike then I'd say fit it yourself. Otherwise, have someone else do it.
gixxersixx
PostPosted: 23:58 - 10 Nov 2006    Post subject: Reply with quote
If youre looking at datatool s4 then these dont come with any fitting instructions so it would have to be done by an approved fitter
We're all just born to die. So lets have some fun
gsxr6k1,pc,k&n,skimmed block,flowed head,yoshi gasket,cams,blue print,arrow system titanium can,quick shifter,gilles rear sets,ktech forks,ohlins shock,galfer waveys, -3front+4rear + other goodies
Ichy
PostPosted: 01:27 - 11 Nov 2006    Post subject: Reply with quote
You don't look that far from me. If you decide to go down the self fit route then I'd be more than happy to help out.
sickpup
Old Timer
PostPosted: 12:57 - 11 Nov 2006    Post subject: Reply with quote
Read the Sig.
Although not sure if I'm approved anymore, must give them a call.
salty21
PostPosted: 14:00 - 11 Nov 2006    Post subject: Reply with quote
its one of those talking ones with remote start and immobiliser it has bout 7 or 8 wires to fit. its just the ignition ones im struggling with
Ichy
PostPosted: 15:42 - 11 Nov 2006    Post subject: Reply with quote
Do you already have it?
Yellow and/ or white wires to the ignition? Remember that the ignition wires go somewhere, usually CDI or fusebox. It might be better to attach there rather than at the more obvious barrel end.
The last post was made 19 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.16 - MySQL Queries: 13 - Page Size: 61.91 Kb
