Lifting arm
airpig
PostPosted: 14:47 - 11 Nov 2006    Post subject: Lifting arm Reply with quote
Hey Peeps!!
Can anyone tell me what could be the reason for oil leaking from underneath my clutch lifting arm? Confused
Cheers.
Bikes are an addiction for which there's no rehab!!
Paddy Blake
PostPosted: 15:24 - 11 Nov 2006    Post subject: Reply with quote
I would think the seal on the shaft is worn.What bike is it.
Paddy.
Ichy
PostPosted: 15:37 - 11 Nov 2006    Post subject: Reply with quote
Probably a 1994 Honda CBR600FR Laughing
airpig
PostPosted: 15:38 - 11 Nov 2006    Post subject: Reply with quote
A 94 cbr600f. Is it ok to remove the arm without draining the oil? Confused
airpig
PostPosted: 15:39 - 11 Nov 2006    Post subject: Reply with quote
You could do stand-up!! Thumbs Up
Paddy Blake
PostPosted: 15:47 - 11 Nov 2006    Post subject: Reply with quote
You would need to tilt the bike well over to the left if you dont want to
drain the oil when doing the seal.You will need the seal and a gasket for
the clutch casing then take off the arm and remove the clutch casing.
You then remove the shaft from the casing.replace the seal and assemble.
Paddy.
airpig
PostPosted: 15:51 - 11 Nov 2006    Post subject: Reply with quote
Will have to get meself a gasket then.
Cheers.
The last post was made 19 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.94 - MySQL Queries: 13 - Page Size: 51.8 Kb
